04-19-2015, 00:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | gt-s7582 network problem i flash with unlock and repair imei software from support and wipe data same problem i try flash with 4 files room low ship and wipe data sane problem i try repair network change imei same problem Network logo is Circular when i change network to gsm only network came to few second and back to same problem .a |
04-19-2015, 07:36 | #2 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | HI, DO NEXT--- 1. DO HARD RESET FIRST 2. RE -FLASH YOUR MOBILE 3. REPAIR IMEI 4. REPAIR NETWORK 5. RE-FLASH AGAIN AND POST RESULTS YOU CAN TRY TO WRITE CERT FILE ALSO All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". |
04-20-2015, 00:31 | #3 (permalink) |
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | hello . Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect GT-S7582 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "UART" radio button to "MODEM" value. 9. Set "USB" radio button to "PDA" value. 10. Press "Save and Reset", phone will restart. 11. Press "Read Info" in software. Selected firmware file: S7582XXUAMK3_S7582OJVAMJ2 _XSG_United_Arab_Emirates_Android_4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-S7582 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing modem section... modem section has been written successfully. Writing DTS section... DTS section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing system section... system section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM12 Selected model: GT-S7582 Connecting to phone on COM62 Detected phone model: GT-S7582 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed Connecting to phone on COM63 Phone connection failed Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM12 Selected model: GT-S7582 Connecting to phone on COM62 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Phone IMEI A: 353408-06-007748-2 Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Old IMEI A: 353408-06-007748-2 New IMEI A: 353408-06-007750-8 Checking Root: Please, press "Allow" button on the phone if it's need. Phone is Rooted. Writing new phone IMEI A... Repairing network. Please wait, this can take some time... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Phone IMEI A: 353408-06-007748-2 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Old IMEI B: 353408-06-007748-2 New IMEI B: 353408-06-007751-6 Checking Root: Please, press "Allow" button on the phone if it's need. Phone is Rooted. Writing new phone IMEI B... Repairing network. Please wait, this can take some time... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Phone IMEI A: 353408-06-007750-8 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Phone IMEI A: 353408-06-007750-8 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Checking Root: Please, press "Allow" button on the phone if it's need. Phone is Rooted. Repairing network. Please wait, this can take some time... Network is successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 PDA version: S7582XXUAMK3 CSC version: S7582OJVAMJ2 SW version: S7582XXUANA1 Phone IMEI: 353408060077508 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Rebooting phone in Download Mode... Phone successfully rebooted in Download Mode. Selected firmware file: CODE_S7582XXUAMK3_2099582_REV00 _user_low_ship.oct Please put the phone into Download Mode and connect USB cable. To put GT-S7582 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing DTS section... DTS section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing modem section... modem section has been written successfully. Writing PIT section... PIT section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM12 Selected model: GT-S7582 Connecting to phone on COM62 Detected phone model: GT-S7582 Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK 3 HW Version: GT-S7582ZKAXSG Phone IMEI A: 353408-06-007750-8 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: GT-S7582 Selected file: C:\Users\w-7\Desktop\Cert-GT-S7582_35160206473668 _RZ1DC213BKH.cert Select Certificate2... Selected file: C:\Users\w-7\Desktop\Cert-GT-S7582_35160306473668 _RZ1DC213BKH.cert Detected phone model: GT-S7582 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 PDA version: S7582XXUAMK3 CSC version: S7582OJVAMJ2 SW version: S7582XXUANA1 Phone IMEI: 353408060077508 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Checking Root: Phone is not Rooted. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: GT-S7582 Selected file: C:\Users\w-7\Desktop\Cert-GT-S7582_35160206473668 _RZ1DC213BKH.cert Select Certificate2... Selected file: C:\Users\w-7\Desktop\Cert-GT-S7582_35160306473668 _RZ1DC213BKH.cert Detected phone model: GT-S7582 Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 PDA version: S7582XXUAMK3 CSC version: S7582OJVAMJ2 SW version: S7582XXUANA1 Phone IMEI: 353408060077508 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK3 HW Version: GT-S7582ZKAXSG Incorrect IMEI Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK3 HW Version: GT-S7582ZKAXSG Incorrect IMEI Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK3 HW Version: GT-S7582ZKAXSG Incorrect IMEI Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 SW version: S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANA1/S7582XXUAMK3 HW Version: GT-S7582ZKAXSG Incorrect IMEI Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) Checking Root: Please, press "Allow" button on the phone if it's need. Phone is Rooted. Repairing network. Please wait, this can take some time... Network is successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Connecting to phone on COM62 Phone connection failed Connecting to phone on COM63 Phone connection failed Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM62 Selected model: GT-S7582 Detected phone model: GT-S7582 Incorrect IMEI Firmware compiled date: Mon Nov 11 09:48:03 KST 2013 Phone SN: R21F320HDKZ Android version: 4.2.2 (JDQ39) same problem |
04-20-2015, 12:55 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to do the next: 1. Write "GT-S7582_for_Unlock_and_IMEI_SN_Repair" firmware from the Support Area. 2. Perform "Repair IMEI" operation. 3. Perform "Repair Network" operation. If problem will remain the same - check phone's HW. |
04-20-2015, 23:18 | #5 (permalink) |
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | hello . i do these steps and same problem . i don't think these hw problem i do replace all ic network before send problem to you there is problem with cert file to s7582 it's 14 numbers not 15 when i write cert imei came Incorrect what about qcn for these device is that possible and these tool not support these option plz check these problem |
04-21-2015, 06:07 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Most likely, this is HW issue, we have tested these devices many times and no were problems with network. | |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
