06-22-2015, 00:13 | #1 (permalink) |
Insane Poster Join Date: Nov 2010 Location: Newport Beach, CA, USA
Member: 1433171 Status: Offline Thanks Meter: 45 | [GUIDE] Fix N910A Boot Loop - Unknown Baseband (step by step) I have a few people asking questions on solution for N910 boot-loop, I want to make step-by-step guide to answer all questions. Problem caused by changing *#9090# and possibly downgrade as well. Takes time, several tries, don't worry. 1. Downgrade to 4.4.4 via Odin. Extract OC4, extract Odin, open Odin, select four files into correct position (BL, AP, CP, CSC) 4.4.4 OC4 Odin 3.09 (Samsung Mobile drivers required) 2. Once on 4.4.4 or below, enable developer options by tapping "build version" several times, enable USB debugging & mock location, and install KingRoot 4.0.0.233 to phone. Caution, newer versions did not work for me. 3. Open "Command Prompt" and type "adb version" should reply with "Android Debug Bridge version x.x.x", if does not, change to the correct directory where adb is installed via "cd" command. Need ADB? Here 4. These next two steps can be a little tricky as the phone often reboots before completed, must work quickly, I suggest copying the long command, then paste when ready. 5. Connect to working WiFi. Turn off your phone, reboot, or wait for it to reboot itself. Soon as phone turns on, open KingRoot, soon as WiFi connected notification appears, touch button in center of KingRoot app, soon as KingRoot reaches 30%, began adb commands. 6. ADB commands: first command "adb shell", second command "su", third command "dd if=/dev/zero of=/dev/block/mmcblk0p10 | dd if=/dev/zero of=/dev/block/mmcblk0p13 | dd if=/dev/zero of=/dev/block/mmcblk0p14 | dd if=/dev/zero of=/dev/block/mmcblk0p15 | dd if=/dev/zero of=/dev/block/mmcblk0p16" phone will reboot or you can reboot and after reboot boot-loop and unknown baseband will be fixed! Can now write new IMEI via "Write Cert" and possibly "Write QCN" if any network troubles, then all good to go! 7. Any questions feel free to contact me on skype: brandon.sisco or phone: 949.482.7058 I'm happy to walk you through any steps. Once you see results, I have worked hard on this complete solution for many weeks, I would appreciate any donation. Secure paypal donate here Thank you ecs87 for the help with adb wipe efs commands |
The Following 20 Users Say Thank You to bsisco For This Useful Post: |
06-22-2015, 07:18 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | Thanks for this useful post..but I've been trying to install Kingroot.apk many times now and it won't install..It keeps staying on installing....Of course I checked unknown source..Do you know why it's not installing? |
06-22-2015, 08:01 | #6 (permalink) |
Member: 59030 Status: Offline Thanks Meter: 165 | Edit: My bad...It installed now. I uncheck Verify Apps in security settings it installed...Once again thanks, now I will try to fix it with your instruction to see if it fixes the bootloop and no basebankd problem..thanks |
The Following User Says Thank You to citifone For This Useful Post: |
06-22-2015, 09:06 | #7 (permalink) |
Member: 59030 Status: Offline Thanks Meter: 165 | Your method works. Phone now has baseband and no more restart bootloop problem. It still has no imei but should be able to fix easily with boxes. Thanks so much for sharing.... |
06-22-2015, 19:56 | #8 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | Quote:
I have got one SM N910A i entered code*#9090*# and select USB option and it went into reboot loop.Wrote the modem only from 5.0.2 firmware,didn't work. Your solution comes into rescue.Thanks for your hard work i appreciate it. Br, Moderate | |
The Following User Says Thank You to Moderate For This Useful Post: |
06-23-2015, 02:55 | #9 (permalink) |
Member: 59030 Status: Offline Thanks Meter: 165 | Phone seems to work now but it's stuck in Factory Mode On and keep turn wifi off and might have other problems associate with this mode but have not known yet. I already wipe factory and wipe cache and reflash the firmware but still the same. Any suggestion to fix this problem? |
06-24-2015, 00:55 | #12 (permalink) | |
Member: 1433171 Status: Offline Thanks Meter: 45 | Quote:
The Following User Says Thank You to bsisco For This Useful Post: |
