07-24-2015, 16:43 | #33 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Jesus. Why do I get all the screwed phones. I have a ATT one someone sent in try to go for a cheap service. Now The root doesn't stick to feed the Android bridge debug lines (ADB). I'm pretty sure it's a app in one of the original blocks that get a conflict, then errors out. I downgraded to 4.4.4 to try to fix it but it boot loops also. Root is being worked on as we speak but it's temporary. @ecs87. Can you chime in on this? I get root to stick but SU is not enabled. Joey's app say's that root is not there. We went through something similar in the old sdx days when I just started almost 10 years ago. Pulling a battery to stop files from reinforcing did wonders to get recoveries on. |
07-28-2015, 17:05 | #38 (permalink) |
Major Poster Join Date: Jul 2015
Member: 2434042 Status: Offline Thanks Meter: 3 | I used the NIE file instead of OC4 as suggested and when I selected AP in Odin and selected the file, I get "Odin md5 error. Binary is invalid" help?! Should I try it with OC4?? |
07-30-2015, 16:35 | #41 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | This process Worked for me, and now My mobile is in Normal mode. Baseband = OK. IMEI = by Cert write. Network = Emergency Mode only. Need QCN file from working phone for solve Network problem. Anyone can shere N910A QCN File ???. |
07-30-2015, 18:51 | #42 (permalink) |
Member: 1633328 Status: Offline Thanks Meter: 37 | Hello guys do you think that I could do this process to a Note 3 without cause any damage ? Another question is where are the efs partition location on Note 3 just in case this process cant be applied to the Note 3? Sent from my iPhone using Tapatalk |
08-01-2015, 17:54 | #43 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1565447 Status: Offline Thanks Meter: 1 | Im stuck on android is upgrading, apps are 48 and reboot after 6 or 7, never finish the process, so i can't do all the stuff, what can i do then? i already flash the firmware via odin... |
08-01-2015, 20:25 | #44 (permalink) | |
Junior Member Join Date: Jan 2014
Member: 2112406 Status: Offline Thanks Meter: 0 | Quote:
i tried going back to a different firmware and coming back to this one, no go, i tried wiping data and cache, still no go... anyone else having this problem? | |
08-02-2015, 00:13 | #45 (permalink) | |
Junior Member Join Date: Jul 2015
Member: 2434784 Status: Offline Thanks Meter: 0 | Quote:
I need to know the right way to wipe efs cuz I followed op instructions but ended up in factory mode. I only have access to add so the only way I can get out of factory mode is through adb commands. Can anyone post the right commands ?, Thanks. | |
