02-28-2017, 09:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | help adout sm-J700F system status : Custom phone condition : hang in samsung logo i will try to update with smart switch so update done but stuck in logo so i will try to reset with recovery so hive me this error can i solve this error witth octo. thanks advance |
02-28-2017, 10:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please make Factory Reset and Wipe cache partition from Recovery Mode, then reflash the phone. |
02-28-2017, 10:29 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to write "J700FXXS2API1_J700FOLB2APG1_GLB_Android_6.0.1 " firmware from the Support Area and post here the result. |
02-28-2017, 10:48 | #5 (permalink) | |
Major Poster Join Date: Jan 2017 Location: india
Member: 2675766 Status: Offline Thanks Meter: 20 | Quote:
thats why its hang on logo, and also comes wifi problem flash with lollipop may be your problem will be solve thanks regards | |
02-28-2017, 15:03 | #6 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | INFO : 28-02-2017 07:18:02 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.4.8 INFO : 28-02-2017 07:18:16 PM > ----------------------------------------------------------------------------------- INFO : 28-02-2017 07:18:16 PM > To connect SM-J700F phone you have to perform the following steps: INFO : 28-02-2017 07:18:16 PM > 1. Disconnect USB cable from phone. INFO : 28-02-2017 07:18:16 PM > 2. Go to Menu->Settings->More->About Device. INFO : 28-02-2017 07:18:16 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 28-02-2017 07:18:16 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 28-02-2017 07:18:16 PM > 5. Turn on "USB Debugging" option. INFO : 28-02-2017 07:18:39 PM > Selected firmware file: J700FXXS2API1_J700FOLB2APG1_GLB_Android_6.0.1.oct WARN : 28-02-2017 07:18:53 PM > Please put the phone into Download Mode and connect USB cable. WARN : 28-02-2017 07:18:53 PM > To put SM-J700F into Download Mode, You have to perform the following steps: WARN : 28-02-2017 07:18:53 PM > 1. Reconnect the battery. WARN : 28-02-2017 07:18:53 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 28-02-2017 07:18:53 PM > 3. When phone turns on, press "Volume+" key. INFO : 28-02-2017 07:18:53 PM > Found phone on INFO : 28-02-2017 07:18:53 PM > Firmware write started. INFO : 28-02-2017 07:18:53 PM > Writing BOOT section... INFO : 28-02-2017 07:18:57 PM > BOOT section has been written successfully. INFO : 28-02-2017 07:18:57 PM > Writing RECOVERY section... INFO : 28-02-2017 07:19:01 PM > RECOVERY section has been written successfully. INFO : 28-02-2017 07:19:01 PM > Writing SYSTEM section... ERROR : 28-02-2017 07:20:01 PM > Writing Firmware Failed INFO : 28-02-2017 07:20:01 PM > Performed by 2.4.8 Software version. WARN : 28-02-2017 07:27:08 PM > Please put the phone into Download Mode and connect USB cable. WARN : 28-02-2017 07:27:08 PM > To put SM-J700F into Download Mode, You have to perform the following steps: WARN : 28-02-2017 07:27:08 PM > 1. Reconnect the battery. WARN : 28-02-2017 07:27:08 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 28-02-2017 07:27:08 PM > 3. When phone turns on, press "Volume+" key. INFO : 28-02-2017 07:27:09 PM > Found phone on INFO : 28-02-2017 07:27:09 PM > Firmware write started. INFO : 28-02-2017 07:27:09 PM > Writing BOOT section... INFO : 28-02-2017 07:27:12 PM > BOOT section has been written successfully. INFO : 28-02-2017 07:27:12 PM > Writing RECOVERY section... INFO : 28-02-2017 07:27:15 PM > RECOVERY section has been written successfully. INFO : 28-02-2017 07:27:15 PM > Writing SYSTEM section... ERROR : 28-02-2017 07:28:14 PM > Writing Firmware Failed INFO : 28-02-2017 07:28:14 PM > Performed by 2.4.8 Software version. |
02-28-2017, 15:10 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please fully charge phone battery and try to reflash the phone again. Try to use different USB ports of PC motherboard for connection. If problem will remain the same - please check phone HW. |
02-28-2017, 15:58 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You receive this error during flashing - try to write "J700FXXU3BPJ1_J700FOJK3BPJ1_ILO_Android_6.0.1 " firmware. |
03-01-2017, 14:32 | #10 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | flash done but hang in samsung logo and show in recovery Code: NFO : 01-03-2017 06:51:53 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.4.8 INFO : 01-03-2017 06:51:58 PM > ----------------------------------------------------------------------------------- INFO : 01-03-2017 06:51:58 PM > To connect SM-J700F phone you have to perform the following steps: INFO : 01-03-2017 06:51:58 PM > 1. Disconnect USB cable from phone. INFO : 01-03-2017 06:51:58 PM > 2. Go to Menu->Settings->More->About Device. INFO : 01-03-2017 06:51:58 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 01-03-2017 06:51:58 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 01-03-2017 06:51:58 PM > 5. Turn on "USB Debugging" option. INFO : 01-03-2017 06:52:01 PM > Selected firmware file: J700FXXU3BPJ1_J700FOJK3BPJ1_ILO_Android_6.0.1.oct WARN : 01-03-2017 06:52:06 PM > Please put the phone into Download Mode and connect USB cable. WARN : 01-03-2017 06:52:06 PM > To put SM-J700F into Download Mode, You have to perform the following steps: WARN : 01-03-2017 06:52:06 PM > 1. Reconnect the battery. WARN : 01-03-2017 06:52:06 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 01-03-2017 06:52:06 PM > 3. When phone turns on, press "Volume+" key. INFO : 01-03-2017 06:52:06 PM > Found phone on INFO : 01-03-2017 06:52:06 PM > Firmware write started. INFO : 01-03-2017 06:52:07 PM > Writing BOOTLOADER section... INFO : 01-03-2017 06:52:09 PM > BOOTLOADER section has been written successfully. INFO : 01-03-2017 06:52:09 PM > Writing CM section... INFO : 01-03-2017 06:52:11 PM > CM section has been written successfully. INFO : 01-03-2017 06:52:11 PM > Writing BOOT section... INFO : 01-03-2017 06:52:15 PM > BOOT section has been written successfully. INFO : 01-03-2017 06:52:15 PM > Writing RECOVERY section... INFO : 01-03-2017 06:52:18 PM > RECOVERY section has been written successfully. INFO : 01-03-2017 06:52:18 PM > Writing SYSTEM section... INFO : 01-03-2017 06:55:05 PM > SYSTEM section has been written successfully. INFO : 01-03-2017 06:55:05 PM > Writing CACHE section... INFO : 01-03-2017 06:55:16 PM > CACHE section has been written successfully. INFO : 01-03-2017 06:55:16 PM > Writing HIDDEN section... INFO : 01-03-2017 06:55:21 PM > HIDDEN section has been written successfully. INFO : 01-03-2017 06:55:21 PM > Writing RADIO section... INFO : 01-03-2017 06:55:26 PM > RADIO section has been written successfully. INFO : 01-03-2017 06:55:26 PM > Firmware writing successfully completed. INFO : 01-03-2017 06:55:26 PM > Performed by 2.4.8 Software version. |
03-01-2017, 16:18 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to write "J700FXXU3BQA2_J700FODD3BPJ2_SLK_Android_6.0.1 " firmware from the Support Area. This is one of the latest firmwares for this model. If after writing of it problem will remain - You should check phone HW. |
