01-20-2015, 15:41 | #1 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277451 Status: Offline Thanks Meter: 18 | Help with baseband UNKNOWN GT-i9003 |
01-20-2015, 16:01 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Quote:
Try to read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button in the Software) and post here full Software log with this info. We will look and will advise You, what to do the next. | ||
01-20-2015, 16:59 | #3 (permalink) |
Member: 2277451 Status: Offline Thanks Meter: 18 | read info didn't work. But as you can see i manually selected as i9100T and read info work. Platform: Samsung Android Selected port: COM45 Selected model: GT-I9003 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM33 Phone connection failed No diagnostic ports found! Connecting to phone on COM50 Phone connection failed ----------------------------------------------------------------------------------- To connect GT-I9100T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: GT-I9100T Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Jun 8 16:09:28 KST 2012 PDA version: I9003XWLF2 CSC version: I9003ITVLF2 SW version: Unknown Phone IMEI: Unknown Android version: 2.3.6 (GINGERBREAD) |
01-20-2015, 17:34 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
