01-11-2014, 01:17 | #1 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1656264 Status: Offline Thanks Meter: 6 | HELP!! can't connect SGH-I747M!!! This is the log I get -------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SGH-I747M Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM49 Mode: Emergency --------------------------------------------- I followed from step 1~14, but I have 1 problem. *#9090# gets me nowhere, I get nothing from it. (which I think this is the main problem here) I tried androd firmware 4.04, 4.1.1, 4.1.2, 4.3 All of them give same results (nothing happens) Yes I tried changing ports, read info on same port multiple times etc I even rooted the phone, but nothing happens However when I do 'read info' on Anroid, EFS Manger tab It does read this Platform: Samsung Android Selected port: COM49 Selected model: SGH-I747M Reading info, please wait... Detected phone model: SGH-I747M Firmware compiled date: Tue Nov 20 22:35:43 KST 2012 PDA version: I747MVLDLK4 CSC version: I747MOYBDLK4 SW version: I747MVLDLK4 Phone IMEI: 353323055819501 Phone SN: R21DB3XX6ZB Android version: 4.1.1 (JRO03L) * I tried read security, read EFS (they both work) But when I change the tab to Main or Repair IMEI/SN It goes back to Platform: Samsung Android Selected port: COM49 Selected model: SGH-I747M Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM49 Mode: Emergency Of course none of the operations work either. I've working on this for many days, and it's driving me crazy!! Could there be a defect with the box itself? |
01-11-2014, 10:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to connect the phone via Micro USB cable. To connect SGH-I747M via Micro USB cable, You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "USB" value. 14. Restart phone. 15. Press "Read Info" in software. If the phone will not be connected via Micro USB cable, try to connect it via Samsung Micro UART C3300k/C3303k cable. To connect SGH-I747M phone via Samsung Micro UART cable, do the next steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. |
01-11-2014, 21:57 | #3 (permalink) |
Member: 1656264 Status: Offline Thanks Meter: 6 | I tried with UART cable (the UART cable I got with the box) but it reads nothing. this is the log ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM34 Selected model: SGH-I747M Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM34 Selected model: SGH-I747M Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM34 Phone connection failed ---------------------------------------------------------------------- In fact any operation related to UART cable never worked with me. and I need answers for these questions *#9090# don't work at all in any firmwares I tried (4.0.4, 4.1.1, 4.1.2, 4.3) How do I set config diag to USB without *#9090#? (it seems they disabled it) I'm able to read info on Android/ EFS manager tab, but Main and Repair IMEI/SN tab don't work at all. Ay idea? |
01-13-2014, 10:11 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
1. Box has HW problem (problem with UART connector or other HW problems). 2. Problem with Samsung Micro UART cable (try to use another cable to be sure, that the cable is OK). Quote:
Please try to use another Samsung Micro UART C3300k/C3303k cable and connect the device again. | ||
01-13-2014, 21:43 | #5 (permalink) | |
Member: 1656264 Status: Offline Thanks Meter: 6 | Quote:
First of all, it's not the problem with my PC since I tried it on 2 different PC (one with newly installed windows 7) and I get the same result. This could be the cable, so I just ordered Samsung Micro UART C3300K/C3303K. Once I get new cable, I'll update you with the process. Thanks. | |
