04-15-2016, 14:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | HELP FRP G531H not working!! ----------------------------------------------------------------------------------- To connect SM-G531H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G531H To put SM-G531H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version i have flashed the phone with several flash files namely: g531hxxu0aoi4_g531hoxe0aoi4_ser_android_5.1.1.oct G531HXXU0AOH4_G531HOXE0AOH4_G531HXXU0AOH4_HOME.tar .md5 but same result Operation was failed! Please help!! |
04-15-2016, 14:36 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Please try to reflash the phone with "g531hubu0aoi2_g531huub0aoi2_upo_android_5.1.1 " firmware from the Support Area, then repeat "Reset FRP/Reactivation/EE" operation. |
04-15-2016, 15:26 | #3 (permalink) |
Member: 121461 Status: Offline Thanks Meter: 49 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-G531H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G531H To put SM-G531H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version Selected firmware file: g531hubu0aoi2_g531huub0aoi2_upo_android_ 5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G531H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G531H To put SM-G531H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version |
04-15-2016, 16:47 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | If phone does not restart after the operation - most likely its firmware has new type of Security, in which Samsung disabled ability to remove FRP lock. You can try to write even older firmware - "G531HXXU0AOH1_G531HOXE0AOH1_SER_Android_5.1.1 ", for example. |
04-22-2016, 16:02 | #8 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 132 | Help... Need solution too Code: INFO : 22/04/2016 17:40:04 > ----------------------------------------------------------------------------------- INFO : 22/04/2016 17:40:06 > Platform: Samsung Android INFO : 22/04/2016 17:40:06 > Selected port: INFO : 22/04/2016 17:40:06 > Selected model: SM-G531H WARN : 22/04/2016 17:40:06 > To put SM-G531H into Download Mode, You have to perform the following steps: WARN : 22/04/2016 17:40:06 > 1. Reconnect the battery. WARN : 22/04/2016 17:40:06 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 22/04/2016 17:40:06 > 3. When phone turns on, press "Volume+" key. INFO : 22/04/2016 17:40:06 > Searching for a phone. Please wait... INFO : 22/04/2016 17:40:06 > Phone found. INFO : 22/04/2016 17:40:06 > Initializing.. INFO : 22/04/2016 17:40:06 > Resetting FRP lock.. SUCC : 22/04/2016 17:40:06 > success INFO : 22/04/2016 17:40:06 > Resetting EE lock.. SUCC : 22/04/2016 17:40:06 > success INFO : 22/04/2016 17:40:06 > Resetting Samsung Account lock.. ERROR : 22/04/2016 17:40:06 > not supported ERROR : 22/04/2016 17:40:06 > Operation was failed! INFO : 22/04/2016 17:40:06 > Performed by 2.2.4 software version INFO : 22/04/2016 17:40:31 > ----------------------------------------------------------------------------------- |
07-22-2016, 23:06 | #11 (permalink) |
No Life Poster Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 59
Member: 296918 Status: Offline Thanks Meter: 122 | g530h I try with two phones from Telcel both were v5.1.1 with revision de seguridad 2016-04-01 and 2016-06-01. Don´t work the FRP reset on cotoplus software. note: I do with another manual method. |
