08-22-2016, 11:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | HELP FRP on G930V Welcome to Octoplus/Octopus Box Samsung software version 2.3.3 ----------------------------------------------------------------------------------- To connect SM-G930V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM31 Selected model: SM-G930V Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G930V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone. Please wait... its been 1 hour and software still can't fine the phone but the phone has restarted and is on the setup screen. I have tried on another pc but same results. anyone has a solution for that |
08-22-2016, 13:46 | #4 (permalink) |
Member: 121461 Status: Offline Thanks Meter: 49 | What i have noticed is that once i run this task when the phone boots in the Computer Management console you do not see the phone in that panel, even if i plug a working phone you do not see it but once i stop the octopus task then the computer management console sees all the phones. this is strange to me. |
