Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-11-2017, 10:32   #1 (permalink)
Member: 1894807
Thanks Meter: 4
Help FRP unlock SM-G935F
Hi all,
when i press to RESET FRP/REACTIVATION/EE octopus begin the download resource of package 39mb, at 100% stop and does not continue.
Tested on Windows 10 x64 i7 hq 16gb ram ssd 500gb toshiba and same
problem is the same with another windows 7 32bit.
Of taskmanager i have killed all tasks and from resource monitoring of taskmanager nothing task use the network.
Old 04-11-2017, 10:53   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Please check that there is no firewall, antivirus or scanning software enabled that would be contributing to this problem.
Alternatively You can download the file manually by link, which we've sent You in PM. Put the file into "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\Downloaded_resourc es\Boot" folder afterwards and You will be good to perform the operation.
The Following 2 Users Say Thank You to Octopus box For This Useful Post:
Old 04-11-2017, 12:12   #3 (permalink)
Member: 1894807
Thanks Meter: 4
Originally Posted by Octopus box View Post
Hello.
Thx you Bro! Now try.
Old 04-11-2017, 13:03   #4 (permalink)
Member: 1894807
Thanks Meter: 4
Unhappy
After flashing phone lock at boot logo
Platform: Samsung Android
Selected port: COM4
Selected model: SM-G935F
Connecting to server...
Could not connect to the server!
Checking resource files...
Resource files already downloaded.
Please put the phone into Download Mode and connect USB cable.
To put SM-G935F into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Waiting for phone...
Firmware write started.
Writing Boot section...
Boot section has been written successfully.
Searching for a phone. Please wait...timeout
Phone not found.
Operation was failed!
Performed by 2.5.1 Software version.
This phone is Downgraded from nougat 7.0 to 6.0.1
AP_G935FXXU1BPH6_CL8888212_QB10596660_REV00_user_l ow_ship.tar.md5
I have try also with combination FW with adb solution, i have make factory reset and reflash original Fw but FRP is ON
COMBINATION_FA60_G935FXXU1APB5.zip
Old 04-11-2017, 13:13   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
If phone gets stuck on logo of writing of "boot.img" - this "boot.img" is not compatible with current firmware of the phone. You can either try to write different firmwares, or try to use combination firmware.
There are two methods, of how to reset FPR using Combination firmware (to enable ADB):
I.
  1. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check all partitions except "boot.img").
  2. Perform "Reset FRP" operation in Software.
II.
  1. Write Full Combination Firmware.
  2. Go to "Developer Options" in phone Settings.
  3. Check "Enable OEM unlock" option.
  4. Make Factory Data Reset.
  5. Reflash the phone with full stock (orignal) firmware.
Note: "boot.img" of Combination firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares).
You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk!
If neither of these methods helps, necessary files are missing, or You don't want to take risk - You can use Factory Reset FRP Service.
Old 04-11-2017, 13:44   #6 (permalink)
Member: 1894807
Thanks Meter: 4
Question
I.
II.
How Can i use frp remote service?
Page generated in 0.18315 seconds with 8 queries
