01-17-2015, 18:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Help with G900w8 Last edited by Octopus box; 01-19-2015 at 08:21. |
01-17-2015, 20:07 | #3 (permalink) | |
Member: 1484663 Status: Offline Thanks Meter: 344 | Quote:
Code: INFO : 1/15/2015 12:23:33 PM > Set up system language English (file: English.ini) INFO : 1/15/2015 12:23:33 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.8.0 INFO : 1/15/2015 12:23:33 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:23:33 PM > To connect SM-G9008W phone you have to perform the following steps: INFO : 1/15/2015 12:23:33 PM > 1. Disconnect USB cable from phone. INFO : 1/15/2015 12:23:33 PM > 2. Go to Menu->Settings->More->About Device. INFO : 1/15/2015 12:23:33 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 1/15/2015 12:23:33 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 1/15/2015 12:23:33 PM > 5. Turn on "USB Debugging" option. INFO : 1/15/2015 12:23:33 PM > 6. Go to dial window. INFO : 1/15/2015 12:23:33 PM > 7. Enter "*#0808#" number. INFO : 1/15/2015 12:23:33 PM > 8. Select "DM+Modem+ADB". INFO : 1/15/2015 12:23:33 PM > 9. Press Home button. INFO : 1/15/2015 12:23:33 PM > 10. Go to dial window. INFO : 1/15/2015 12:23:33 PM > 11. Enter "*#9090#" number. INFO : 1/15/2015 12:23:33 PM > 12. Set "Diag config" to "USB" value. INFO : 1/15/2015 12:23:33 PM > 13. Restart phone. INFO : 1/15/2015 12:23:33 PM > 14. Press "Read Info" in software. INFO : 1/15/2015 12:23:54 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:23:54 PM > To connect SM-N900W8 phone you have to perform the following steps: INFO : 1/15/2015 12:23:54 PM > 1. Disconnect USB cable from phone. INFO : 1/15/2015 12:23:54 PM > 2. Go to Menu->Settings->More->About Device. INFO : 1/15/2015 12:23:54 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 1/15/2015 12:23:54 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 1/15/2015 12:23:54 PM > 5. Turn on "USB Debugging" option. INFO : 1/15/2015 12:23:54 PM > 6. Go to dial window. INFO : 1/15/2015 12:23:54 PM > 7. Enter "*#0808#" number. INFO : 1/15/2015 12:23:54 PM > 8. Select "DM+Modem+ADB". INFO : 1/15/2015 12:23:54 PM > 9. Press Home button. INFO : 1/15/2015 12:23:54 PM > 10. Go to dial window. INFO : 1/15/2015 12:23:54 PM > 11. Enter "*#9090#" number. INFO : 1/15/2015 12:23:54 PM > 12. Set "Diag config" to "USB" value. INFO : 1/15/2015 12:23:54 PM > 13. Restart phone. INFO : 1/15/2015 12:23:54 PM > 14. Press "Read Info" in software. INFO : 1/15/2015 12:43:25 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:43:25 PM > Platform: Samsung Android INFO : 1/15/2015 12:43:25 PM > Selected port: COM320 INFO : 1/15/2015 12:43:25 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:43:26 PM > Phone was not found on the selected port! INFO : 1/15/2015 12:43:26 PM > Searching for USB diagnostic port... INFO : 1/15/2015 12:43:26 PM > Connecting to phone on COM319 INFO : 1/15/2015 12:43:26 PM > Mode: Normal INFO : 1/15/2015 12:43:26 PM > Phone model: SM-N900W8 INFO : 1/15/2015 12:43:26 PM > Firmware compiled date: May 10 2014 INFO : 1/15/2015 12:43:26 PM > Firmware compiled time: 03:00:00 INFO : 1/15/2015 12:43:26 PM > Firmware released date: Jun 16 2014 INFO : 1/15/2015 12:43:26 PM > Firmware released time: 10:11:32 INFO : 1/15/2015 12:43:26 PM > Phone IMEI: 352308-06-181555-2 INFO : 1/15/2015 12:43:26 PM > SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 INFO : 1/15/2015 12:43:30 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:43:30 PM > Platform: Samsung Android INFO : 1/15/2015 12:43:30 PM > Selected port: COM319 INFO : 1/15/2015 12:43:30 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:43:30 PM > Mode: Normal INFO : 1/15/2015 12:43:30 PM > Phone model: SM-N900W8 INFO : 1/15/2015 12:43:30 PM > Firmware compiled date: May 10 2014 INFO : 1/15/2015 12:43:30 PM > Firmware compiled time: 03:00:00 INFO : 1/15/2015 12:43:30 PM > Firmware released date: Jun 16 2014 INFO : 1/15/2015 12:43:30 PM > Firmware released time: 10:11:32 INFO : 1/15/2015 12:43:30 PM > Phone IMEI: 352308-06-181555-2 INFO : 1/15/2015 12:43:30 PM > SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 INFO : 1/15/2015 12:43:33 PM > Reading NVM... INFO : 1/15/2015 12:44:38 PM > Reading NVM done! INFO : 1/15/2015 12:45:10 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:45:10 PM > Platform: Samsung Android INFO : 1/15/2015 12:45:10 PM > Selected port: COM319 INFO : 1/15/2015 12:45:10 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:45:10 PM > Reading info... INFO : 1/15/2015 12:45:10 PM > Mode: Normal INFO : 1/15/2015 12:45:10 PM > Firmware compiled date: May 10 2014 INFO : 1/15/2015 12:45:10 PM > Firmware compiled time: 03:00:00 INFO : 1/15/2015 12:45:10 PM > Firmware released date: Jun 16 2014 INFO : 1/15/2015 12:45:10 PM > Firmware released time: 10:11:32 INFO : 1/15/2015 12:45:10 PM > SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 INFO : 1/15/2015 12:45:13 PM > Reading QCN... INFO : 1/15/2015 12:45:13 PM > Send SPC... INFO : 1/15/2015 12:45:13 PM > Reading mobile property... INFO : 1/15/2015 12:45:13 PM > Mobile property read successfully INFO : 1/15/2015 12:45:13 PM > Reading feature mask... INFO : 1/15/2015 12:45:13 PM > Feature mask read successfully INFO : 1/15/2015 12:45:13 PM > Reading roaming list 0 INFO : 1/15/2015 12:45:13 PM > Reading roaming list 0 read successfully INFO : 1/15/2015 12:45:13 PM > Reading NV items... INFO : 1/15/2015 12:45:42 PM > NV items read successfully INFO : 1/15/2015 12:45:42 PM > Reading NV SIM1 items... INFO : 1/15/2015 12:46:11 PM > NV SIM1 items read successfully INFO : 1/15/2015 12:46:11 PM > Reading NV SIM2 items... INFO : 1/15/2015 12:46:43 PM > NV SIM2 items read successfully INFO : 1/15/2015 12:46:43 PM > Reading NV items... INFO : 1/15/2015 12:46:47 PM > NV items read successfully INFO : 1/15/2015 12:46:47 PM > Reading EFS... INFO : 1/15/2015 12:46:47 PM > EFS read successfully INFO : 1/15/2015 12:46:47 PM > Reading provisioning items... INFO : 1/15/2015 12:46:50 PM > Provisioning items read successfully INFO : 1/15/2015 12:46:50 PM > Reading QCN done! INFO : 1/15/2015 12:46:50 PM > QCN read successfully INFO : 1/15/2015 12:47:16 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:47:16 PM > Platform: Samsung Android INFO : 1/15/2015 12:47:16 PM > Selected port: COM319 INFO : 1/15/2015 12:47:16 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:47:17 PM > ADB server killed. WARN : 1/15/2015 12:47:19 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 1/15/2015 12:48:05 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:48:05 PM > Platform: Samsung Android INFO : 1/15/2015 12:48:05 PM > Selected port: COM319 INFO : 1/15/2015 12:48:05 PM > Selected model: SM-N900W8 WARN : 1/15/2015 12:48:08 PM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 1/15/2015 12:48:10 PM > Warning: Selected model (SM-N900W8) differs from the detected one (SM-G900W8)! INFO : 1/15/2015 12:48:10 PM > If you want select (SM-G900W8) as (SM-N900W8) model, please check "manual select". INFO : 1/15/2015 12:48:10 PM > Checking Root: ERROR : 1/15/2015 12:48:10 PM > Reading security failed. INFO : 1/15/2015 12:48:22 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:48:22 PM > Platform: Samsung Android INFO : 1/15/2015 12:48:22 PM > Selected port: COM319 INFO : 1/15/2015 12:48:22 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:48:22 PM > Reading info, please wait... WARN : 1/15/2015 12:48:23 PM > Warning: Selected model (SM-N900W8) differs from the detected one (SM-G900W8)! INFO : 1/15/2015 12:48:23 PM > If you want select (SM-G900W8) as (SM-N900W8) model, please check "manual select". INFO : 1/15/2015 12:48:27 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:48:27 PM > Platform: Samsung Android INFO : 1/15/2015 12:48:27 PM > Selected port: COM320 INFO : 1/15/2015 12:48:27 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:48:27 PM > Reading info, please wait... WARN : 1/15/2015 12:48:28 PM > Warning: Selected model (SM-N900W8) differs from the detected one (SM-G900W8)! INFO : 1/15/2015 12:48:28 PM > If you want select (SM-G900W8) as (SM-N900W8) model, please check "manual select". INFO : 1/15/2015 12:48:37 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:48:37 PM > Platform: Samsung Android INFO : 1/15/2015 12:48:37 PM > Selected port: COM320 INFO : 1/15/2015 12:48:37 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:48:37 PM > Reading info, please wait... INFO : 1/15/2015 12:48:38 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:48:38 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:48:38 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:48:39 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:48:39 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:48:40 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:48:41 PM > Phone SN: RV8F41RB4HR INFO : 1/15/2015 12:48:41 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:48:44 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:48:44 PM > Platform: Samsung Android INFO : 1/15/2015 12:48:44 PM > Selected port: COM320 INFO : 1/15/2015 12:48:44 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:48:47 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:48:47 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:48:47 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:48:48 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:48:48 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:48:49 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:48:50 PM > Phone SN: RV8F41RB4HR INFO : 1/15/2015 12:48:50 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:48:50 PM > Checking Root: INFO : 1/15/2015 12:48:55 PM > Phone is Rooted. INFO : 1/15/2015 12:48:55 PM > Reading security backup, please wait... INFO : 1/15/2015 12:49:17 PM > Security read successfully. INFO : 1/15/2015 12:49:27 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:49:27 PM > Platform: Samsung Android INFO : 1/15/2015 12:49:27 PM > Selected port: COM320 INFO : 1/15/2015 12:49:27 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:49:29 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:49:29 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:49:30 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:49:30 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:49:31 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:49:32 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:49:32 PM > Phone SN: RV8F41RB4HR INFO : 1/15/2015 12:49:32 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:49:32 PM > Checking Root: INFO : 1/15/2015 12:49:33 PM > Phone is Rooted. INFO : 1/15/2015 12:49:33 PM > Reading EFS, please wait... INFO : 1/15/2015 12:49:43 PM > EFS read successfully. INFO : 1/15/2015 12:50:40 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:50:40 PM > Platform: Samsung Android INFO : 1/15/2015 12:50:40 PM > Selected port: COM320 INFO : 1/15/2015 12:50:40 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:50:41 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:50:41 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:50:41 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:50:42 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:50:43 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:50:44 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:50:45 PM > Phone SN: RV8F41RB4HR INFO : 1/15/2015 12:50:45 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:50:45 PM > Reading info... INFO : 1/15/2015 12:50:45 PM > Mode: Normal INFO : 1/15/2015 12:50:45 PM > Firmware compiled date: May 10 2014 INFO : 1/15/2015 12:50:45 PM > Firmware compiled time: 03:00:00 INFO : 1/15/2015 12:50:45 PM > Firmware released date: Jun 16 2014 INFO : 1/15/2015 12:50:45 PM > Firmware released time: 10:11:32 INFO : 1/15/2015 12:50:45 PM > SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 INFO : 1/15/2015 12:50:45 PM > Reading QCN... INFO : 1/15/2015 12:50:45 PM > Send SPC... INFO : 1/15/2015 12:50:45 PM > Reading mobile property... INFO : 1/15/2015 12:50:45 PM > Mobile property read successfully INFO : 1/15/2015 12:50:45 PM > Reading feature mask... INFO : 1/15/2015 12:50:45 PM > Feature mask read successfully INFO : 1/15/2015 12:50:45 PM > Reading roaming list 0 INFO : 1/15/2015 12:50:45 PM > Reading roaming list 0 read successfully INFO : 1/15/2015 12:50:45 PM > Reading NV items... INFO : 1/15/2015 12:51:49 PM > NV items read successfully INFO : 1/15/2015 12:51:49 PM > Reading NV SIM1 items... INFO : 1/15/2015 12:52:52 PM > NV SIM1 items read successfully INFO : 1/15/2015 12:52:52 PM > Reading NV SIM2 items... INFO : 1/15/2015 12:53:56 PM > NV SIM2 items read successfully INFO : 1/15/2015 12:53:56 PM > Reading NV items... INFO : 1/15/2015 12:54:06 PM > NV items read successfully INFO : 1/15/2015 12:54:06 PM > Reading EFS... INFO : 1/15/2015 12:54:06 PM > EFS read successfully INFO : 1/15/2015 12:54:06 PM > Reading provisioning items... INFO : 1/15/2015 12:54:11 PM > Provisioning items read successfully INFO : 1/15/2015 12:54:11 PM > Reading QCN done! INFO : 1/15/2015 12:54:12 PM > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-N900W8-352308061815552-15-01-2015_12-50-45-.qcn file INFO : 1/15/2015 12:54:12 PM > Checking Root: INFO : 1/15/2015 12:54:13 PM > Phone is Rooted. INFO : 1/15/2015 12:54:13 PM > Reading security backup, please wait... INFO : 1/15/2015 12:55:13 PM > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N900W8-352308061815552-15-01-2015_12-54-13-.asec file INFO : 1/15/2015 12:55:13 PM > Wiping EFS... INFO : 1/15/2015 12:55:56 PM > EFS wipe successfully INFO : 1/15/2015 12:55:57 PM > Phone will restart now, plaese wait 1-2 minutes INFO : 1/15/2015 12:55:57 PM > Searching for a phone. Please wait... INFO : 1/15/2015 12:56:27 PM > Reading info... INFO : 1/15/2015 12:56:27 PM > Mode: Normal INFO : 1/15/2015 12:56:27 PM > Firmware compiled date: May 10 2014 INFO : 1/15/2015 12:56:27 PM > Firmware compiled time: 03:00:00 INFO : 1/15/2015 12:56:27 PM > Firmware released date: Jun 16 2014 INFO : 1/15/2015 12:56:27 PM > Firmware released time: 10:11:32 INFO : 1/15/2015 12:56:27 PM > SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 INFO : 1/15/2015 12:56:27 PM > Send SPC... INFO : 1/15/2015 12:56:27 PM > SPC send successfully INFO : 1/15/2015 12:56:27 PM > Writing QCN... INFO : 1/15/2015 12:56:27 PM > Writing NV items... INFO : 1/15/2015 12:56:35 PM > NV items write successfully INFO : 1/15/2015 12:56:35 PM > Writing NV SIM1 items... INFO : 1/15/2015 12:56:35 PM > NV SIM1 items write successfully INFO : 1/15/2015 12:56:35 PM > Writing NV SIM2 items... INFO : 1/15/2015 12:56:35 PM > NV SIM2 items write successfully INFO : 1/15/2015 12:56:35 PM > Wrting EFS... INFO : 1/15/2015 12:56:40 PM > EFS write successfully INFO : 1/15/2015 12:56:40 PM > Writing provisioning items... INFO : 1/15/2015 12:56:43 PM > Provisioning items write successfully. INFO : 1/15/2015 12:56:43 PM > Writing QCN done INFO : 1/15/2015 12:56:43 PM > Wipe security successfully complete. INFO : 1/15/2015 12:56:43 PM > Phone will restart now, plaese wait 1-2 minutes INFO : 1/15/2015 12:57:29 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:57:29 PM > Platform: Samsung Android INFO : 1/15/2015 12:57:29 PM > Selected port: COM320 INFO : 1/15/2015 12:57:29 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:57:41 PM > Selected file: J:\Celulares\BOXES\Octopus\Certs\Cert-SM-G850F-355210060328784-RF8F90BLAFZ.cert INFO : 1/15/2015 12:57:42 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:57:42 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:57:42 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:57:43 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:57:44 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:57:45 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:57:45 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:57:45 PM > Checking Root: INFO : 1/15/2015 12:57:46 PM > Phone is Rooted. INFO : 1/15/2015 12:57:46 PM > Checking Certificate file... INFO : 1/15/2015 12:57:46 PM > Certificate file successfully checked INFO : 1/15/2015 12:57:46 PM > Writing Certificate... INFO : 1/15/2015 12:57:46 PM > Phone connected successfully INFO : 1/15/2015 12:57:46 PM > Writing new phone IMEI... ERROR : 1/15/2015 12:58:07 PM > Writing Certificate failed INFO : 1/15/2015 12:58:20 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 12:58:20 PM > Platform: Samsung Android INFO : 1/15/2015 12:58:20 PM > Selected port: COM320 INFO : 1/15/2015 12:58:20 PM > Selected model: SM-N900W8 INFO : 1/15/2015 12:58:25 PM > Selected file: J:\Celulares\BOXES\Octopus\Certs\Cert-SM-G850F-355210060328784-RF8F90BLAFZ_2.cert INFO : 1/15/2015 12:58:25 PM > Detected phone model: SM-G900W8 INFO : 1/15/2015 12:58:25 PM > Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 INFO : 1/15/2015 12:58:26 PM > PDA version: G900W8VLU1ANF3 INFO : 1/15/2015 12:58:27 PM > CSC version: G900W8OYA1ANF3 INFO : 1/15/2015 12:58:27 PM > SW version: G900W8VLU1ANF3 INFO : 1/15/2015 12:58:28 PM > Phone IMEI: 352308061815552 INFO : 1/15/2015 12:58:29 PM > Android version: 4.4.2 (KOT49H) INFO : 1/15/2015 12:58:29 PM > Checking Root: INFO : 1/15/2015 12:58:30 PM > Phone is Rooted. INFO : 1/15/2015 12:58:30 PM > Checking Certificate file... INFO : 1/15/2015 12:58:30 PM > Certificate file successfully checked INFO : 1/15/2015 12:58:30 PM > Writing Certificate... INFO : 1/15/2015 12:58:30 PM > Phone connected successfully INFO : 1/15/2015 12:58:30 PM > Writing new phone IMEI... ERROR : 1/15/2015 12:58:51 PM > Writing Certificate failed INFO : 1/15/2015 1:00:25 PM > ----------------------------------------------------------------------------------- INFO : 1/15/2015 1:00:25 PM > Platform: Samsung Android INFO : 1/15/2015 1:00:25 PM > Selected port: COM320 INFO : 1/15/2015 1:00:25 PM > Selected model: SM-N900W8 INFO : 1/15/2015 1:00:28 PM > Operation was canceled ERROR : 1/15/2015 1:00:28 PM > Writing Certificate failed | |
01-18-2015, 10:42 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from your Software log, You have not perforrmed "Wipe Security" operation. After performing this operation, IMEI becomes "Unknown", but in your case IMEI is not "Unknown": Quote:
1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security. 4. When the IMEI becomes "Unknown", Write Certificate. Please look here: http://forum.gsmhosting.com/vbb/f684.../#post10768983. | |
01-19-2015, 04:21 | #5 (permalink) |
Member: 1484663 Status: Offline Thanks Meter: 344 | AS I can see from your reply you still donīt know why the security itīs not completly wipe and IMEI remains after the process. Hope you can find soon an update to fix this problem. I did the same you advise me (factory reset etc) but the phone itīs locked by samsung account and it reboot whenever I conect it to wifi. Thatīs my real problem! How can I solve that I ask you. Please help. BR Last edited by Octopus box; 01-19-2015 at 08:08. |
01-19-2015, 08:10 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please look here and try to reset Samsung Account: https://www.youtube.com/watch?v=E41tLyi59II |
