01-11-2017, 18:58 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2671454 Status: Offline Thanks Meter: 0 | Help with Galaxy on5 from Metro [Solved] Please I need help with SM-G550T1. I unlocked the phone with Octoplus Box but now I get no signal on the Phone. PLEASE HELP... Thank you. Last edited by Octopus box; 01-13-2017 at 16:30. |
01-11-2017, 20:43 | #2 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
Find the security backup and write security backup. If everything is ok then reflash your phone and try again | |
The Following User Says Thank You to Alexandroid For This Useful Post: |
01-11-2017, 21:07 | #3 (permalink) |
Member: 2671454 Status: Offline Thanks Meter: 0 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.6 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G550T1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing security failed. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G550T1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G550T1 Firmware compiled date: Wed Jun 8 19:16:22 KST 2016 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 SW version: unknown Phone SN: RV8HB26PC9A Android version: 6.0.1 (MMB29K) Sales code: TMK Country: USA HW platform: exynos3 HW Chip: exynos3475 HW Modem: unknown Security patch level: 2016-06-01 Codename: on5ltemtr Checking Root: Phone is not Rooted. Writing security failed. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G550T1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G550T1 Firmware compiled date: Wed Jun 8 19:16:22 KST 2016 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 SW version: unknown Phone SN: RV8HB26PC9A Android version: 6.0.1 (MMB29K) Sales code: TMK Country: USA HW platform: exynos3 HW Chip: exynos3475 HW Modem: unknown Security patch level: 2016-06-01 Codename: on5ltemtr Checking Root: Phone is not Rooted. Reading security failed. Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G550T1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G550T1 Firmware compiled date: Wed Jun 8 19:16:22 KST 2016 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 SW version: unknown Phone SN: RV8HB26PC9A Android version: 6.0.1 (MMB29K) Sales code: TMK Country: USA HW platform: exynos3 HW Chip: exynos3475 HW Modem: unknown Security patch level: 2016-06-01 Codename: on5ltemtr Checking Root: Writing security failed. Performed by 2.4.6 Software version. |
01-11-2017, 22:07 | #6 (permalink) | |
Reflash your phone with this firmware. This is full firmware 4 packs https://www.androidfilehost.com/?fid=24723757092307401 Then try again If you need root i can help you too. | |
01-11-2017, 22:14 | #7 (permalink) | |
SW version: unknown This means that you have problems with your modem software. You need write security backup and re flash Only with this steps you can unlock | |
01-11-2017, 22:34 | #8 (permalink) |
Member: 2671454 Status: Offline Thanks Meter: 0 | I did reflash the phone, and root it again the whole process. but when it tells me the phone is sucessfully unlocked, the phone restarts by itself and when it boots it shows no sim / no signal |
01-12-2017, 00:00 | #9 (permalink) | |
Post here the exactly log after reflash Did you speak spanish? | |
01-12-2017, 00:03 | #10 (permalink) | |
Just update the samsung software. In 2.4.6 the unlock not work, it has bugs. Just need use the 2.4.7 and done Do the same write security backup. Reflash and unlock but this time 2.4.7 and it is done | |
01-12-2017, 02:21 | #12 (permalink) |
Member: 2395490 Status: Offline Thanks Meter: 515 | Bro just remove sim card and unlock with octoplus samsung 2.4.7 Men sin sim y con la versión 2.47. La 2.4.6 no funciona bien. Ya saber describes el backup para regresar al estado anterior y reflash. Luego root y unlock. Asi de fácil. |
01-12-2017, 08:54 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Mr. Alexandroid is correct. Problem with "Unlock" operation was fixed in the latest Software version. Please download and install 2.4.7 version of the Software, write first Security backup back into the phone, then repeat "Unlock" operation and post here the result. |
