01-11-2016, 01:17 | #1 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1771227 Status: Offline Thanks Meter: 1 | 😯 help!!! I need certificate g928t |
01-11-2016, 11:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Install test Software version. 2. Make Factory Reset and reflash the phone. 3. Write First Security backup back into the phone. 4. Repeat "Unlock" operation. Post here result and full Software log of performed operations. |
01-13-2016, 00:13 | #3 (permalink) |
Member: 1771227 Status: Offline Thanks Meter: 1 | Hi, i download de test software, install and repeat the unlock process. The unlock completed but the same problem persist. I see in other post the same problem and solve when install other version of Android version and i install the same version but not unlock. Any sugestion? Thanks! |
01-13-2016, 10:55 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do the next: 1. Write first Security backup back into the phone. 2. Make Factory Reset 3. Reflash the phone with "G928TUVU2COJ5_G928TTMB2COJ5_TMB_Android_5.1.1 " firmware from the Support Area. 4. Repeat "Unlock" operation. Post here the result. |
01-14-2016, 10:31 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can use Cert files of SM-G928F from "Samsung/For unlock and repair/Certificates" folder of the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. Last edited by Octopus box; 01-14-2016 at 20:51. |
02-17-2016, 18:34 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Currently we don't have another compatible Certificates for this model. You can read Cert from another compatible model and use it for your phone. Cert files compatibility |
