Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 09-07-2012, 15:45   #1 (permalink)
paabu12's Avatar
Member: 605364
HELP!!! I9100g dead with octopus flash file [Solved]
I was trying to unlock a Samsung i900G but its dead now
This is what it says with the help on octopus and I followed it
5. Direct Unlock
  1. Install necessary driver;
  2. Write rooted firmware GT-I9100_XXKG1_rooted.oct;
  3. Connect powered-on phone to PC via Micro USB cable;
  4. Click "Unlock" button;
  5. Follow software instructions (prompts).
I flashed with this file and now I dont have a phone. Customer furious!
I need help!!!!!!
The Following User Says Thank You to paabu12 For This Useful Post:
Old 09-07-2012, 15:55   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Post here full software log with write wirmware procedure.
Old 09-07-2012, 21:04   #3 (permalink)
paabu12's Avatar
Member: 605364
This is the log and all I have is a display of SAMSUNG GALAXY II GT-I9100G
Then a yellow Triangle with exclamation !
Welcome to Octopus Box Samsung software version 1.5.9
To connect GT-I9100 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "PDA" value.
8. Close window.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in Octopus Samsung software.
Selected firmware file: GT-I9100_XXKG1_rooted.oct
Please put your phone in download mode and connect to PC.
To put GT-I9100 phone into download mode you have to perform the following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing PIT section...
PIT section has been written successfully.
Writing FACTORYFS section...
FACTORYFS section has been written successfully.
Writing DATAFS section...
DATAFS section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Writing PARAM section...
PARAM section has been written successfully.
Writing KERNEL section...
KERNEL section has been written successfully.
Writing BOOT section...
BOOT section has been written successfully.
Writing SBL1 section...
SBL1 section has been written successfully.
Writing MODEM section...
MODEM section has been written successfully.
Firmware writing successfully completed.
Old 09-07-2012, 21:10   #4 (permalink)
ZiDanRO's Avatar
Member: 1722871
I'm sad to say that I9100 is not the same with I9100G. You are sore that was the root file for I9100G?
The phone start with a computer and a phone on the display?
The Following User Says Thank You to ZiDanRO For This Useful Post:
Old 09-07-2012, 21:16   #5 (permalink)
paabu12's Avatar
Member: 605364
Cool
Yeah if you see my first post, or if you check the help section of samsung octopus software help, those were the instructions and i followed.
So take a keen look and see that I did no wrong
Old 09-07-2012, 21:21   #6 (permalink)
ZiDanRO's Avatar
Member: 1722871
I think you followed the instructions but the instructions where wrong I know you didn't think about that. But that was happening. Look at this Let me google that for you
Old 09-07-2012, 21:46   #7 (permalink)
ZiDanRO's Avatar
Member: 1722871
I have checked the I9100 and I9100G intructions in Octopus Help and they are wrong becouse they are the same and the phones hardware is not the same. You can't flash I9100 on I9100G or I9100G on I9100.
Again if you have computer exclamation and phone, that is download mode for I9100G and you can flash it verry easy, but this time with good I9100G firmware. Look at support they put today a firmware. Maybe special for you
Old 09-07-2012, 23:46   #8 (permalink)
paabu12's Avatar
Member: 605364
The second line of my post says, "a yellow Triangle with exclamation !"
Old 09-08-2012, 02:13   #9 (permalink)
paabu12's Avatar
Member: 605364
The problem is the flash files are in support but when you select i9100G in octopus software, flashing is not supported you have to select other versions. Hmmmmm, my customer is really furious for bricking her phone, really bad!
Old 09-08-2012, 07:31   #10 (permalink)
ZiDanRO's Avatar
Member: 1722871
You need to learn how to use other software for Samsung flash. The best software for flashing is Odin ver 1.85 for I9100/G/P/T. But you will need a firmware from **************** for your model.
You will put the file in PDA and Start Maybe you are lucky.
Old 09-08-2012, 08:26   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
@ paabu12
Please, re-flash the phone with the firmware for GT-I9100G from the support area.
Old 09-08-2012, 08:54   #12 (permalink)
Ionel's Avatar
Member: 81232
U can't flash a i9100g with i9100 firmware , u can write with odin , u need to write this pit file , and search for I9100GXWKJ2_I9100GODDKJ2_I9100GDDKI1_HOME.tar.md5 flash file , pit file u put on pit box , and flash file on PDA .
Old 09-08-2012, 09:14   #13 (permalink)
ZiDanRO's Avatar
Member: 1722871
You need PIT only if you can't resurect directly with I9100GXWKJ2_I9100GODDKJ2_I9100GDDKI1_HOME.tar.md5 And if you used PIT file when was flashed I9100 firmware and I think Octopus file don't include a PIT.
Old 09-08-2012, 17:35   #14 (permalink)
paabu12's Avatar
Member: 605364
Originally Posted by Octopus box View Post
@ paabu12
Again, you Cannot reflash because there is no write firmware option when you chose i9100g in octopus software
Write option not enabled!!!!!!!!!!!!!!
FROM OCTOPUS SOFTWARE
Selected firmware file: I9100GXWKH8_I9100GOJVKG1_I9100GDZKH5_HOME.oct
Found phone on
File has been created for a different phone model.
Old 09-08-2012, 17:50   #15 (permalink)
paabu12's Avatar
Member: 605364
Tried samfirmware files with odin and converted some files with octopus too but flashing i9100g is not enabled in octopus.
I have all odin versions, phone will flash then end up with the spinning android or reboot menu
For 10years never had such a problem. I have medusa jtag but don't know how to use it
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 3.34464 seconds with 7 queries
