03-13-2016, 14:58 | #1 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Indonesia
Member: 2209602 Status: Offline Thanks Meter: 48 | help imei SM-G7102 failed.. Select service IMEI from the list. Connect powered-on phone to PC via USB cable. fix imei..but failed.. Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM29 Selected model: SM-G7102 Detected phone model: SM-G7102 Firmware compiled date: Mon Oct 6 21:06:20 KST 2014 PDA version: G7102DDUBNJ2 CSC version: G7102ODDBNJ1 SW version: Unknown Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI: Unknown New IMEI: 352310-06-126683-6 Repairing IMEI A... Write IMEI failed Performed by 2.2.2 software version |
03-14-2016, 11:27 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
