12-12-2016, 01:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | Help with this log 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM22 Modelo seleccionado: SM-J500M Selected file must be *.cert Writing Certificate failed The phone dont ask the pin code from any sim card.. but the imei is ok.. and is "pass" any help tanks |
12-12-2016, 09:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What operation You're want perform with the phone exactly? To perofrm "Write Cert" operaiton You need to select a correct Certificate file, with *.cert extension. |
12-16-2016, 02:10 | #6 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | After unlock Plataforma: Samsung Android Porto seleccionado: COM22 Modelo seleccionado: SM-J500M Modelo do telefone detectado: SM-J500M Data de criação do firmware: Wed Jun 1 22:20:29 KST 2016 PDA version: J500MUBU1APF1 CSC version: J500MJDI1APF1 Versão do SW: J500MUBU1APF1 Phone SN: 00000000000 Android version: 5.1.1 (LMY48B) Sales code: JDI Country: JAMAICA HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2016-06-01 Codename: j5lteub Checking Root: Phone is Rooted. Liberando o telefone... O telefone foi liberado com êxito To finish the operation, please restart the phone via phone's menu. Performed by 2.4.6 Software version. when i try to write cert Plataforma: Samsung Android Porto seleccionado: COM22 Modelo seleccionado: SM-J500M Selected file: C:\Users\PC\Desktop\SuperGSM-Cert\J500m1.cert Select Certificate2... Selected file: C:\Users\PC\Desktop\SuperGSM-Cert\J500m2.cert Modelo do telefone detectado: SM-J500M Data de criação do firmware: Wed Jun 1 22:20:29 KST 2016 PDA version: J500MUBU1APF1 CSC version: J500MJDI1APF1 Versão do SW: J500MUBU1APF1 Phone SN: 00000000000 Android version: 5.1.1 (LMY48B) Sales code: JDI Country: JAMAICA HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2016-06-01 Codename: j5lteub Checking Root: Phone is not Rooted. Certificate has been written successfully Para aplicar os câmbios, reinicie o telefone Performed by 2.4.6 Software version. now the phone have one imei "01" and other imei ok but dont get any service... |
12-16-2016, 09:34 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from Software log, your phone has one the latest firmwares: Quote:
Note: downgrading of phone firmware can damage your device. You can try to do this only on your own risk. | |
12-18-2016, 23:36 | #8 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | After flash same problem: Cert: Plataforma: Samsung Android Porto seleccionado: COM22 Modelo seleccionado: SM-J500M Selected file: C:\Users\PC\Desktop\SuperGSM-Cert\J500m1.cert Select Certificate2... Selected file: C:\Users\PC\Desktop\SuperGSM-Cert\J500m2.cert Modelo do telefone detectado: SM-J500M Data de criação do firmware: Sat Aug 22 00:20:31 KST 2015 PDA version: J500MUBU1AOH6 CSC version: J500MZTO1AOH1 Versão do SW: J500MUBU1AOH6 Phone SN: 00000000000 Android version: 5.1.1 (LMY48B) Sales code: ZTO Country: Brazil HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: j5lteub Checking Root: Phone is not Rooted. Certificate has been written successfully Para aplicar os câmbios, reinicie o telefone Performed by 2.4.6 Software version. Unlock: Plataforma: Samsung Android Porto seleccionado: COM22 Modelo seleccionado: SM-J500M Modelo do telefone detectado: SM-J500M Data de criação do firmware: Sat Aug 22 00:20:31 KST 2015 PDA version: J500MUBU1AOH6 CSC version: J500MZTO1AOH1 Versão do SW: J500MUBU1AOH6 Phone SN: 00000000000 Android version: 5.1.1 (LMY48B) Sales code: ZTO Country: Brazil HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: j5lteub Checking Root: Phone is Rooted. Liberando o telefone... O telefone foi liberado com êxito To finish the operation, please restart the phone via phone's menu. Performed by 2.4.6 Software version. Imei status: /01 359xxxxxxxxx |
12-19-2016, 09:13 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem with writing of a Cert file. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
12-20-2016, 09:01 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | There's only a *.log file available for download by link, which You've posted. Please upload both *.log and *.logx files of performed operations and post here download link. *.logx file has the same title as *.log file. |
12-21-2016, 01:24 | #12 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | here logx: https://ufile.io/5b131 |
12-29-2016, 01:04 | #15 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | I already write new imei.. now sim 1 and two are ok.. and when i check imei i have: m(pass) (s) pass But now the problem is that the phone dont ask pin.. already try another sim.. already make unlock operation.. 100% software.. |
