05-29-2014, 20:17 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2175448 Status: Offline Thanks Meter: 0 | help me 9005 imei Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM7 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: |
05-29-2014, 20:33 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Your phone was not connected correctly: Quote:
1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart thephone. 14. Connect the phone directly to PC motherboard USB port. 15. Press "Read Info" in software. | |
05-29-2014, 21:44 | #6 (permalink) | |
Member: 2175448 Status: Offline Thanks Meter: 0 | Quote:
nothing to do, I installed another firmware but nothing keeps giving me a black screen. but when I press the button on the bottom left exit a menu that says input key, end, wifi etc etc.. I am only enter numbers, but nothing | |
05-30-2014, 07:06 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Turn on USB Debugging Mode in the phone, read out phone's info via ADB (press "Read info" button at "Android / EFS manager" tab in Software) and post here full Software log with this info. |
05-30-2014, 11:34 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, connect the device via Micro USB cable, turn on USB Debugging Mode in the phone, press "Read info" button at "Android / EFS manager" tab in Software and post here full Software log with read phone's info. |
05-30-2014, 11:36 | #13 (permalink) | |
Selected port: COM5 Selected model: SM-N9005 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM7 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Teamviewer ???? | |
05-30-2014, 11:52 | #15 (permalink) |
Member: 2175448 Status: Offline Thanks Meter: 0 | Platform : Samsung Android Selected port : COM3 Selected model: SM- N9005 Reading info , please wait ... Proper Android device not found . Make shure That " USB debugging " option on the device is turned on . ps the cable and usb3.0 and I've enabled USB debugging |
