08-12-2013, 18:50 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 52
Member: 117004 Status: Offline Thanks Meter: 1 | HELP ME ABOUT-GT-I 9505 ROOT with octobus 1.2.8 octoplus Select ADB shell option in "APPS" tab; Select "Grant" in Access options; Press Save button; I downloaded supersu application from google play store AND Ran Ican't find ADB SHELL OPTION where can i find but i can select ''grant'' in SUPERSU application could you please tell me how can I find and apply step by step.thank you in advance |
08-13-2013, 08:58 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please carefully perform all the steps from software manual: 1. Put phone into Download mode. 2. Connect phone to PC via Micro USB cable. 3. Install required driver. 4. Select "Root_GT-I9505.oct" firmware file. 5. Click "Write firmware" button. 6. Power on the phone and run "SuperSu" application. Quote:
7. Select ADB shell option in "APPS" tab. 8. Select "Grant" in Access options. 9. Press Save button. | |
08-24-2013, 15:57 | #7 (permalink) |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Hi, for this I9505 ANY ODIN whith ROOT FILE IS WORKING, please ceck first of write Fake info, For Root this Phone, can use EASY the file "ROOT I9505.oct" from Bootloader, any other Attempt whith Odin or other tools get always "MODEM FAIL ERROR", we are Lucky having OCTOPUS/OCTOPLUS BOX, Br Max |
08-24-2013, 16:34 | #8 (permalink) | |
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
1) Power On the Phone, 2) Go in "APPLICATIONES" from Menu', 3) Go in "SETTING" tabulate, 4) Have 4 Sub menu, loock "OTHER", 5) Go in "INFO DEVICE", 6) Loock for "BUILD VERSION", 7) Click here 7 (seven) Times, 8) OK, Now u can see "You are Development Now" 9) Back Key, select "DEVELPMENT OPTION", 10) Ceck "DEBUG USB" Now have Put I9505 in "DEBUG USB" MODE, but not have finish Prepair Phone, go in "DIAL WINDOW" from *#9090# and set in this mode: 5. Go to dial window. 6. Enter "* # 7284 #" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "* # 9090 #" number. 10. Select "[4] DM over UART (*)". 11. Restart phone. 12. Press "Read Info" in software. Be Warning, Often Menu' key *#7284# is not working, no matter, go direct in point 9 to 12, phone is working the same whith OCTOPUS for READ INFO. *Point 6: Tip for Menu' Key *#7284#, Insert Uart Cable and write the string above in Keypad, now is Working this Menu' Key, select UART to MODEM Value, -ADB SHELL, is one Modality that goes the Phones whith "CORRECT ANDROID DRIVERS" -u r are WRONG whith u r Download by Google Play, have done Mistake whith Root, now read and Aplly Step by Step this "Prepair Phone", -Try other time Now, first READ INFO, then Write "Root File I9505.oct" and post .....FULL LOG here...., I hope all this can be of help for many users, Br Max/Ripgsm | |
