02-23-2017, 09:29 | #1 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2487681 Status: Offline Thanks Meter: 6 | HELP ME custom binary blocked by frp SM-J700H أرسلت من MHA-L29 بإستخدام تاباتلك |
The Following User Says Thank You to waad zeko For This Useful Post: |
02-23-2017, 10:14 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. What exactly You want to do with the phone? Reflash it, or remove FRP lock? Please post here full Software log of performed operations. |
02-23-2017, 10:16 | #4 (permalink) | |||
Member: 2487681 Status: Offline Thanks Meter: 6 | Quote:
أرسلت من MHA-L29 بإستخدام تاباتلك Quote:
أرسلت من MHA-L29 بإستخدام تاباتلك Last edited by Octopus box; 02-23-2017 at 11:15. | |||
02-23-2017, 11:13 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Please try to write "J700HXXU2BPL1_J700HOJV2BPL1_BTC_Android_6.0.1 " firmware from the Support Area and post here the result. |
02-25-2017, 02:20 | #7 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2541673 Status: Offline Thanks Meter: 39 | you have to go to Developer Options and enable OEM unlock option. in settings tap Build Number 8 times, then go to settings - Developer Options OEM UNLOCK - YES this is the error msg i get when i try to flash a phone with that option off you might have to reflash with stock, then enable OEM Unlock then flash the file you are trying to get on it Last edited by bmc613; 02-25-2017 at 02:25. |
02-25-2017, 04:22 | #8 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Remove FRP... Bro search for s boot file...flash to enable advice..then remove FRP via advice...OR flash combo...turn on oem remove from and reset then flash stock rom bk on device. |
