04-07-2015, 10:43 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: India
Member: 2069212 Status: Offline Sonork: 12345678 Thanks Meter: 5 | Help me OCTOPLUS TEAM about samsung s530h [Solved] i have a samsung s530h handset, it was working good, for this i just needed repair imei, so i write cert file by octoplus tool, but after writing cert file network is not accessing.. here is log... Platform: Samsung Android Selected port: COM42 Selected model: SM-G530H Selected file: C:\Documents and Settings\tanveer\Desktop\Cert_SM- G530H_355************.cert Select Certificate2... Selected file: E:\FILES\PLUS FILES\SAMSUNG\G530H\Cert_SM-G530H_ 355************.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM42 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Kindly help me team... Last edited by Octopus box; 04-07-2015 at 15:44. |
04-07-2015, 10:50 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to write QCN backup, that was created by Software, when You wiped Security. Also try to write QCN from the Support Area. If this will not help, try to find and write other IMEI Certificates, most likely, IMEIs from IMEI Certificates files, which You have written, is in the "black" list of your network operator. |
