-   Octopus Samsung/Octoplus Samsung (http://forum.gsmhosting.com/vbb/f684/)
-   -   Help Me Octopus Team !!!!!!!!! [Solved] (http://forum.gsmhosting.com/vbb/f684/help-me-octopus-team-solved-1453993/)
Devashish Mobile 04-03-2012 06:06
Hello Octopus Team i am in Big Prob. i Read Sam T499 in Z3x For Unlock But After Read Phone goes in Blinking Mode.....
1st : After Blink i have flash in Odin with : T499UVKE4-T499UVKE4-T499UVKE4-HOME But SAME PROB.
2nd : i Repair Boot in RIFF box ( Before repair boot my phone already goes in Download mode ) then i flash with again : T499UVKE4-T499UVKE4-T499UVKE4-HOME , but SAME PROBLEM
3rd : i read this post : http://forum.gsmhosting.com/vbb/f664...a-but-1449343/ , Then i decide and purchase New " Octopus Samsung "....
4th : i flashe phone in Octopus Sam with this FW : T499UVKE4-T499UVKE4-T499UVKE4.oct Then Try with SGH-T499V_SW_KG23.oct But No Luck Same Prob Then i try with SGH-T499Y_95_SW_95_SKG2.oct BUT SAME PROB........
SO PLEASE ADVICE ME OCTOPUS TEAM AND PLS ALIVE MY PHONE AGAIN IN WORKING CON.....
THAX IN ADV. Cont :- ICQ : 619329104 & sonork : 100.1605386
mr.omphonx 04-03-2012 06:20
maybe can help you here
http://forum.gsmhosting.com/vbb/f664...olved-1436484/
Devashish Mobile 04-03-2012 06:37
Thax for rply mr. mr.omphonx but i have not MedusaBox i have RIFF JTAG.....
Octopus box 04-03-2012 06:57
Hello.
Try to do the next:
1. Make Erase Full flash with any Jtag tool You have and Repair the phone.
2. Re-flash the phone with Octops Box Samsung software with "T499UVKE4-T499UVKE4-T499UVKE4.oct" firmware from the support area.
Devashish Mobile 04-03-2012 07:08
ok sir thax for rply i will try and post result...........
Devashish Mobile 04-03-2012 08:17
hello sir ,
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK
WARNING: Erasing Error (0x24) at 0x00000FBC0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00000FCC0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001EA00000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001EE00000 is Ignored. Erase continues.
Completed in 00:00:12.777 (Average Transfer Rate: 41033.73 kB/s)
Repai Boot :::
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.31, JTAG Manager Version: 1.41
Selected Resurrector: [Samsung T499 V1.0.4449.56799]
Connecting to the dead body...OK
Detected dead body ID: 0x203C00E1 - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Selected Resurrection Data for the NAND Chip with Page size = 4KB
Flashing the dead body...OK
Resurrection complete!
after that i flash with octopus but same result phone blinking...........
Devashish Mobile 04-03-2012 08:21
To connect SGH-T499 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "Diag config" to "USB" value.
8. Restart phone.
9. Press "Read Info" in Octopus Samsung software.
Selected firmware file: T499UVKE4-T499UVKE4-T499UVKE4.oct
Please put your phone in download mode and connect to PC.
To put SGH-T499 phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume-" +"Power" buttons.
Searching for phone. Please wait...
Found phone on
Firmware write started.
Writing amss section...
amss section has been written successfully.
Writing boot.img section...
boot.img section has been written successfully.
Writing recovery.img section...
recovery.img section has been written successfully.
Writing system.rfs section...
system.rfs section has been written successfully.
Writing csc.rfs section...
csc.rfs section has been written successfully.
Please, restart phone to apply changes
Firmware writing successfully completed.
BUT PHONE STILL BLINKING...............
Octopus box 04-03-2012 08:51
As I see from the log abow - there are some errors during of erasing... Try to perform these operations using Medusa Box.
Devashish Mobile 04-03-2012 08:55
but i have no medusabox, so pls give me other sol. thax
Octopus box 04-03-2012 08:57
There is no another solution - need to erase full flash and repair the phone correctly.
Devashish Mobile 04-09-2012 08:56
Yes Yes Yes, Thank you Medusa & Octopus Samsung, My T499 Alive again and working GOOD Now by Repair in 1st Medusa & Then Reflash in Octopus Samsung.....
Thanks Medusa & Octopus Samsung For Gr8 Work And Offcourse Gr8 Suppt.....
Page generated in 0.25034 seconds with 5 queries
