Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-03-2012, 06:06   #1 (permalink)
Devashish Mobile's Avatar
Member: 130050
Thanks Meter: 82
Help Me Octopus Team !!!!!!!!! [Solved]
Hello Octopus Team i am in Big Prob. i Read Sam T499 in Z3x For Unlock But After Read Phone goes in Blinking Mode.....
1st : After Blink i have flash in Odin with : T499UVKE4-T499UVKE4-T499UVKE4-HOME But SAME PROB.
2nd : i Repair Boot in RIFF box ( Before repair boot my phone already goes in Download mode ) then i flash with again : T499UVKE4-T499UVKE4-T499UVKE4-HOME , but SAME PROBLEM
3rd : i read this post : T499 reboot in after root in z3x done via medusa,but? , Then i decide and purchase New " Octopus Samsung "....
4th : i flashe phone in Octopus Sam with this FW : T499UVKE4-T499UVKE4-T499UVKE4.oct Then Try with SGH-T499V_SW_KG23.oct But No Luck Same Prob Then i try with SGH-T499Y_95_SW_95_SKG2.oct BUT SAME PROB........
SO PLEASE ADVICE ME OCTOPUS TEAM AND PLS ALIVE MY PHONE AGAIN IN WORKING CON.....
THAX IN ADV. Cont :- ICQ : 619329104 & sonork : 100.1605386
Old 04-03-2012, 06:20   #2 (permalink)
mr.omphonx's Avatar
Member: 714648
Sonork: 1609640
Thanks Meter: 901
maybe can help you here
Help me T499 TDO lost [Solved]
The Following User Says Thank You to mr.omphonx For This Useful Post:
Old 04-03-2012, 06:37   #3 (permalink)
Member: 130050
Thanks Meter: 82
Thax for rply mr. mr.omphonx but i have not MedusaBox i have RIFF JTAG.....
Old 04-03-2012, 06:57   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 19,783
Hello.
Try to do the next:
1. Make Erase Full flash with any Jtag tool You have and Repair the phone.
2. Re-flash the phone with Octops Box Samsung software with "T499UVKE4-T499UVKE4-T499UVKE4.oct" firmware from the support area.
The Following 2 Users Say Thank You to Octopus box For This Useful Post:
Old 04-03-2012, 07:08   #5 (permalink)
Member: 130050
Thanks Meter: 82
ok sir thax for rply i will try and post result...........
Old 04-03-2012, 08:17   #6 (permalink)
Member: 130050
Thanks Meter: 82
hello sir ,
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK
WARNING: Erasing Error (0x24) at 0x00000FBC0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00000FCC0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001EA00000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001EE00000 is Ignored. Erase continues.
Completed in 00:00:12.777 (Average Transfer Rate: 41033.73 kB/s)
Repai Boot :::
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.31, JTAG Manager Version: 1.41
Selected Resurrector: [Samsung T499 V1.0.4449.56799]
Connecting to the dead body...OK
Detected dead body ID: 0x203C00E1 - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Selected Resurrection Data for the NAND Chip with Page size = 4KB
Flashing the dead body...OK
Resurrection complete!
after that i flash with octopus but same result phone blinking...........
Old 04-03-2012, 08:21   #7 (permalink)
Member: 130050
Thanks Meter: 82
To connect SGH-T499 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "Diag config" to "USB" value.
8. Restart phone.
9. Press "Read Info" in Octopus Samsung software.
Selected firmware file: T499UVKE4-T499UVKE4-T499UVKE4.oct
Please put your phone in download mode and connect to PC.
To put SGH-T499 phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume-" +"Power" buttons.
Searching for phone. Please wait...
Found phone on
Firmware write started.
Writing amss section...
amss section has been written successfully.
Writing boot.img section...
boot.img section has been written successfully.
Writing recovery.img section...
recovery.img section has been written successfully.
Writing system.rfs section...
system.rfs section has been written successfully.
Writing csc.rfs section...
csc.rfs section has been written successfully.
Please, restart phone to apply changes
Firmware writing successfully completed.
BUT PHONE STILL BLINKING...............
Old 04-03-2012, 08:51   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
As I see from the log abow - there are some errors during of erasing... Try to perform these operations using Medusa Box.
Old 04-03-2012, 08:55   #9 (permalink)
Member: 130050
Thanks Meter: 82
but i have no medusabox, so pls give me other sol. thax
Old 04-03-2012, 08:57   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
There is no another solution - need to erase full flash and repair the phone correctly.
Old 04-09-2012, 08:56   #11 (permalink)
Member: 130050
Thanks Meter: 82
Yes Yes Yes, Thank you Medusa & Octopus Samsung, My T499 Alive again and working GOOD Now by Repair in 1st Medusa & Then Reflash in Octopus Samsung.....
Thanks Medusa & Octopus Samsung For Gr8 Work And Offcourse Gr8 Suppt.....
The Following User Says Thank You to Devashish Mobile For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 09:21
Page generated in 0.40586 seconds with 8 queries
