Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 05-01-2013, 00:48   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 225
help no service on GT-I9300 [Solved]
i unlock but no service found please help me
Welcome to Octopus Box Samsung software version 1.8.2
To connect GT-S5830 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#9090#" number.
7. Set "Diag config" to "USB" value.
8. Restart phone.
9. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM16
Selected model: GT-I9300
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Rooting phone failed.
Operation was canceled
Please switch your phone to the download mode and connect it to a
PC.
To put GT-I9300 phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Firmware writing successfully completed.
Selected port: COM1
Searching for a phone. Please wait...
Phone found.
Firmware compiled date: Tue Aug 21 17:13:30 KST 2012
Phone SN: RF1C5871W8B
Android version: 4.0.4 (IMM76D)
Unlocking phone...
Phone is successfully unlocked
Selected port: COM1
Phone found.
Old 05-01-2013, 01:19   #2 (permalink)
Thorenzz's Avatar
Member: 1176876
Sonork: 100.1607051
Thanks Meter: 153
Check the imei with *#06# if it shows 044xxxxxxxxxxxx (not correct imei) then EFS its demaged,,, try to repair EFS, then write imei. Make sure h have c3300k micro uart cable as u will need it for imei repair. After whole procedure restart phone twice. It may take while to pick up network first time after efs and imei repair.
Sent from my GT-I9300 using Tapatalk 2
Old 05-01-2013, 01:23   #3 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 225
also need to repair IMEI
but i em stuck on this?
To connect GT-I9300 phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in software.
Selected port: COM3
Reading info, please wait...
Selected port: COM3
Detected phone model: GT-I9300
Phone SN: 00000000000
Selected port: COM3
Phone found.
Old IMEI: Unknown
New IMEI: 353164-05-092540-0
Erasing old IMEI. It can take some time. Please wait...
Creating NVM backup
Backup saved as C:\Program Files\GsmServer\OctopusSamsung
\BACKUP\NVDATA-GT-I9300-01-05-2013_13-17-42-.nvm file
Old IMEI was erased successfully.
Phone will restart now
After phone being rebooted and powered on perform the following
steps:
1. Disconnect USB cable.
2. Go to dial window.
3. Enter *#9090# number.
4. Set speed to 115200.
5. Connect phone via UART cable to Box.
Connecting to phone, please wait...
please help if i use the wrong cable i use Rextor Micro UART AT170
thanks
Old 05-01-2013, 05:52   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,931
You need to use Samsung Micro UART cable C3300k/C3303k with 530 kOhm resistor inside. Whether there is a resistor in your cable? Most likely, You use standart Micro UART cable...
The Following User Says Thank You to Octopus box For This Useful Post:
Old 05-01-2013, 23:09   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 225
i dont have that cable i will order it
Old 05-02-2013, 02:13   #6 (permalink)
Thorenzz's Avatar
Member: 1176876
Sonork: 100.1607051
Thanks Meter: 153
Thats why i told u in my post: "make sure u have c3300k uart cable."
The Following User Says Thank You to Thorenzz For This Useful Post:
Old 07-22-2013, 02:16   #7 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 225
and here the result cable already order from GSM Server with happy result for me now
Welcome to Octopus Box Samsung software version 1.9.4
9. Reboot phone.
Selected port: COM3
Phone was not found on the selected port!
Searching for USB diagnostic port...
No diagnostic ports found!
Connecting to phone on COM3
Phone connection failed
Selected port: COM3
Selected action canít be performed
Selected port: COM3
Selected port: COM3
Phone found.
Selected port: COM3
Phone found.
Repairing Serial Number. It can take some time. Please wait...
SN repaired successfully.
Selected port: COM3
Phone found.
Selected port: COM3
Phone found.
Unlocking phone...
Selected port: COM3
Phone found.
Selected port: COM3
Phone found.
Old IMEI: Unknown
Creating NVM backup
\BACKUP\NVDATA-GT-I9300-22-07-2013_13-33-03-.nvm file
steps:
Phone connected successfully
Deactivating MSL...
MSL deactivate successfully
Writing new phone IMEI...
New IMEI successfully written.
Please, restart the phone to apply changes
Selected port: COM3
Phone found.
Selected port: COM3
Phone found.
Selected port: COM3
Phone found.
Page generated in 0.32027 seconds with 7 queries
