07-03-2013, 07:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | SHV E120L failed to read unlock code octopus box software managed to read nvm of this phone but unlock code failed... see logs Code: Welcome to Octopus Box Samsung software version 1.8.0 ----------------------------------------------------------------------------------- To connect SHV-E120L phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "0821" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM8 Selected model: SHV-E110S Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM43 Detected phone model: SHV-E120L HW Version: LGT Phone IMEI: 358096-04-139589-4 Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM8 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM43 Selected model: SHV-E110S Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM43 Selected model: SHV-E110S Detected phone model: SHV-E120L HW Version: LGT Phone IMEI: 358096-04-139589-4 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM43 Detected phone model: SHV-E120L HW Version: LGT Phone IMEI: 358096-04-139589-4 Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM43 Selected model: SHV-E120L Detected phone model: SHV-E120L HW Version: LGT Phone IMEI: 358096-04-139589-4 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM43 Detected phone model: SHV-E120L HW Version: LGT Phone IMEI: 358096-04-139589-4 Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- To connect SHV-E120S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "996412" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SHV-E120L phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "0821" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM43 Selected model: SHV-E120L Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM50 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM49 Selected model: SHV-E120L Mode: Normal Phone model: Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM50 Mode: Emergency ----------------------------------------------------------------------------------- To connect SHV-E120L phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "0821" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM50 Selected model: SHV-E120L Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM53 Phone connection failed Connecting to phone on COM56 Mode: Normal Phone model: SCAQSVZQ Phone model is not supported Phone connection failed Connecting to phone on COM45 Mode: Emergency ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM55 Selected model: SHV-E110S Mode: Normal Phone model: AAABQNSZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQNSZ)! Firmware compiled date: Oct 05 2011 Firmware compiled time: 19:00:00 Firmware released date: Jul 11 2012 Firmware released time: 14:38:44 Phone IMEI: 358096-04-139589-4 WiFi MAC: 00:00:00:00:00:00 SW Version: M8660A-AABQNSZM-3.1.61119ST ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM55 Selected model: SHV-E110S Mode: Normal Phone model: AAABQNSZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQNSZ)! Firmware compiled date: Oct 05 2011 Firmware compiled time: 19:00:00 Firmware released date: Jul 11 2012 Firmware released time: 14:38:44 Phone IMEI: 358096-04-139589-4 WiFi MAC: 00:00:00:00:00:00 SW Version: M8660A-AABQNSZM-3.1.61119ST Reading NVM... Reading NVM done! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM55 Selected model: SHV-E110S Mode: Normal Phone model: AAABQNSZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQNSZ)! Firmware compiled date: Oct 05 2011 Firmware compiled time: 19:00:00 Firmware released date: Jul 11 2012 Firmware released time: 14:38:44 Phone IMEI: 358096-04-139589-4 WiFi MAC: 00:00:00:00:00:00 SW Version: M8660A-AABQNSZM-3.1.61119ST Reading phone unlock codes. It can take some time, please wait... Read codes failed ----------------------------------------------------------------------------------- To connect SHV-E120K phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SHV-E120L phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "0821" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM55 Selected model: SHV-E110S Mode: Normal Phone model: AAABQNSZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQNSZ)! Firmware compiled date: Oct 05 2011 Firmware compiled time: 19:00:00 Firmware released date: Jul 11 2012 Firmware released time: 14:38:44 Phone IMEI: 358096-04-139589-4 WiFi MAC: 00:00:00:00:00:00 SW Version: M8660A-AABQNSZM-3.1.61119ST ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM55 Selected model: SHV-E110S Mode: Normal Phone model: AAABQNSZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQNSZ)! Firmware compiled date: Oct 05 2011 Firmware compiled time: 19:00:00 Firmware released date: Jul 11 2012 Firmware released time: 14:38:44 Phone IMEI: 358096-04-139589-4 WiFi MAC: 00:00:00:00:00:00 SW Version: M8660A-AABQNSZM-3.1.61119ST Reading phone unlock codes. It can take some time, please wait... Read codes failed |
