12-20-2014, 18:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Install/re-install SAMSUNG USB Driver for Mobile Phones and restart PC. Try to use different USB ports of PC for connection, try to use another, clean (with only required drivers and Software installed) PC. |
12-20-2014, 19:00 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Indonesia Raya
Member: 636569 Status: Offline Thanks Meter: 192 | Quote:
still the same sir.......... help *#0808# set to DM-MODEM_ADB *#9090# set log via usb and speed 11520 *#7284# set UART modem and USB modem,uart pda usb pda,uart pda usb modem still the same | |
12-20-2014, 19:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | To connect GT-N5100 you only need to enable "USB Debugging" mode, no other changes in device's setting required. Make "Factory Reset", enable "USB Debugging" mode and connect device directly to PC. If problem remains the same - re-flash the device. |
06-12-2015, 16:01 | #5 (permalink) | |
Junior Member Join Date: May 2015
Member: 2398801 Status: Offline Thanks Meter: 0 | I did everything but the problem continues Quote:
