06-09-2014, 11:59 | #1 (permalink) |
Banned Join Date: Apr 2007
Member: 489582 Status: Offline Thanks Meter: 2 | help octopus team and also baseband unknown.... --------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9100 Detected phone model: GT-I9100 Firmware compiled date: Wed Sep 11 00:18:15 KST 2013 PDA version: I9100XWLSZ CSC version: I9100ORGLS1 SW version: Unknown Phone IMEI: Unknown Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Erasing old IMEI. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Write IMEI failed |
06-09-2014, 12:04 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from your Software log, phone's modem part is damaged: Quote:
At first, try to re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), perform "Repair EFS" and "Repair IMEI" operatios. It is not possible to repair IMEI, if phone's modem part is damaged. | |
06-09-2014, 13:06 | #5 (permalink) |
Member: 489582 Status: Offline Thanks Meter: 2 | baseband still unknown Selected firmware file: I9100XWLSZ_I9100ORGLS1 _Switzerland_Android_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. |
06-09-2014, 13:07 | #6 (permalink) |
Member: 489582 Status: Offline Thanks Meter: 2 | Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM4 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Sep 11 00:18:15 KST 2013 PDA version: I9100XWLSZ CSC version: I9100ORGLS1 SW version: Unknown Phone IMEI: Unknown Android version: 4.1.2 (JZO54K) |
06-09-2014, 13:26 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to write different firmwares, not only one. If after of writing all firmwares, which You have, phone's modem part will be still Unknown - most likely, this is HW problem (the problem is with phone's flash chip). |
