10-07-2016, 05:50 | #1 (permalink) |
Major Poster Join Date: Sep 2010 Location: aerth
Member: 1405816 Status: Offline Thanks Meter: 25 | help octupos team after frp reset blink logo ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-A510Y Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-A510Y into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.3.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-A510Y Connecting to server... Could not connect to the server! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-A510Y into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.3.7 Software version. |
10-07-2016, 07:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). |
