04-02-2014, 14:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 48
Member: 129953 Status: Offline Thanks Meter: 2 | help repair i9505 jb 4.3 [Solved] ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM184 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM184 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM183 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM183 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 35xxxx-01-xxxxx-4 Creating NVM backup Reading NVM done! Firmware compiled date: Tue Nov 19 17:28:16 KST 2013 PDA version: I9505XXUEMK8 CSC version: I9505WINEMJ8 SW version: I9505XXUEMK8 Phone IMEI: Unknown Phone SN: RF1D616F3VA Android version: 4.3 (JSS15J) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-02-04-2014_15-01-55-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Nov 19 2013 Firmware released time: 18:15:03 SW version: M9615A-CEFWTAZM-4.0.17125 Found phone on COM184 Repairing NVM for GT-I9505 phone... Write IMEI failed Last edited by Octopus box; 04-03-2014 at 13:04. |
04-02-2014, 14:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do the next: 1. Install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual). 2. Write firmware with 4.4.2 Android version. 3. Root the device manually. 4. Disable KNOX. 5. Write firmware "GT-i9505_for_Unlock_and_IMEI_repair". 6. Repeat "Repair IMEI" operation. 7. Write here the result. |
04-02-2014, 15:16 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 45
Member: 49428 Status: Offline Thanks Meter: 45 | You sure there is no problem with 4.4.2? I highly suggest DO NOT upgrade to 4.4.2 because you will have a lot of trouble and also trigger Knox as well. After 4.4.2 cannot even downgrade... Last edited by Octopus box; 04-02-2014 at 15:27. |
04-02-2014, 16:58 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
1. Root the device manually whith "VRoot English", when instal the Update start, (4.3 is supported for root). 2. Disable KNOX. 3. Write firmware "GT-i9505_for_Unlock_and_IMEI_repair". 4. Read EFS and Security 5. Repeat "Repair IMEI" operation. 6. Not Disconnect device after reboot and ceck Imei 7. Insert Sim and if not have Signal, Use Repair 3G/4G 8. Write here the result. WARNING, if you try to WIPE/FACTORY RESET lost signal, if change FW lost signal, is Patched metod, no definitive whith 4.3 version and Knox, so not change more fw, when repair imei is definitive you will can change fw w/o lost signal | |
04-02-2014, 21:12 | #5 (permalink) |
Member: 129953 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.2 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: For_Unlock_and_IMEI_Repair_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM183 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 356270-01-546709-4 Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM183 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 356270-01-546709-4 Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM183 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 35xxxx-01-xxxxxxx-4 Creating NVM backup Reading NVM done! Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505ITVFNB2 SW version: I9505XXUAMDC Phone IMEI: Unknown Phone SN: RF1D616F3VA Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-02-04-2014_22-07-56-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM184 Repairing NVM for GT-I9505 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
04-02-2014, 22:01 | #7 (permalink) |
Member: 129953 Status: Offline Thanks Meter: 2 | Platform: Samsung Android Selected port: COM184 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 35xxxx-01-xxxxx-4 SW version: M9615A-CEFWTAZM-4.0.17062 Repairing 3G/4G... 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM184 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-671216-7 SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- |
04-03-2014, 09:52 | #8 (permalink) |
Member: 49428 Status: Offline Thanks Meter: 45 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 356266-05-422348-9 Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading security failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: |
04-03-2014, 10:48 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please download "I9505XXUFNA1-MODEM.oct" modem file from Support Area and write it into the phone as a firmware. After this try to make Repair IMEI. |
04-03-2014, 11:22 | #11 (permalink) |
Member: 49428 Status: Offline Thanks Meter: 45 | https://www.boot-loader.com/eng/octopus_free_section <--- don't see it here |
04-03-2014, 11:31 | #12 (permalink) | |
The Following User Says Thank You to allumts For This Useful Post: |
