Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-15-2016, 18:18   #1 (permalink)
Member: 2190785
Thanks Meter: 29
Smile Help repair imei G920t1 with invalid security [Solved]
hello
i have a customer the its appear the he erase the imei of the phone with no backup am trying to repair but octuplus say security backup damage, the way the i resolve this was writing back the security backup but i don't have it for this specific phone..
i need help trying to put the same or any imei on the phone.. thnks
SM-G920T1
PHONE HAD FACTORY DEFAULT IMEI 3500000000000006
OCTOPLUS 2.2.2
Platform: Samsung Android
Selected port: COM15
Selected model: SM-G920T1
Selected file: C:\Users\Repair\Desktop\SAMSUNG G920T\cert-sm-g920t-357746060831994-r58g31myxyb.cert
Detected phone model: SM-G920T1
Firmware compiled date: Tue Mar 31 04:30:13 KST 2015
PDA version: G920T1UVU1AOCH
CSC version: G920T1TMB1AOCH
SW version: G920T1UVU1AOCH
Phone SN: R58G41D95YT
Android version: 5.0.2 (LRX22G)
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920T1-Unknown15-03-2016_12-00-57-.asec file
Checking Certificate file...
Certificate file successfully checked
Phone connected successfully
Writing certificate...
Security damaged, please Repair Security and try again
Performed by 2.2.2 software version
Old 03-15-2016, 18:21   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Please perform "Repair Security" operation, then repeat "Write Cert" operation. Post here result and full Software log of performed operations.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 03-15-2016, 19:06   #3 (permalink)
Member: 2190785
Thanks Meter: 29
ohh well that simple.. it works thanks.
ADB server killed.
Phone SN: RF1D45EJGGR
Checking Root:
Phone is Rooted.
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920T1-Unknown15-03-2016_13-34-51-.asec file
Wiping EFS...
Phone will restart now. Please don't disconnect cable!
EFS wipe successfully
Searching for a phone. Please wait...
Can't kill external ADB references. Please, close all programs that use ADB server.
Repairing security
Security repair successfully
ADB server killed.
Checking Root:
Phone is Rooted.
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920T1-Unknown15-03-2016_13-39-40-.asec file
Certificate has been written successfully
Please, restart the phone to apply changes
Old 04-02-2016, 06:56   #4 (permalink)
Member: 2238757
[10:50:00 AM] prosssopheap: Welcome to Octoplus/Octopus Box Samsung software version 2.2.3
To connect SM-N920T phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
To connect SM-G920T1 phone you have to perform the following
steps:
Selected port: COM19
ADB server killed.
Phone found.
Firmware compiled date: Tue Oct 27 22:45:57 KST 2015
PDA version: G920T1UVU3DOJ6
CSC version: G920T1TMB3DOJ6
SW version: G920T1UVU3DOJ6
Phone IMEI: Unknown
Phone SN: R58G60DD8ST
Android version: 5.1.1 (LMY47X)
Performed by 2.2.3 software version
Selected file: Z:\Samsung\SM-G920T1\cert-sm-g920t-
Checking Root:
Phone is Rooted.
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-SM-G920T1-Unknown01-04-2016_10-43-58-.asec
file
Deactivating MSL...
Executing exploit...
Exploit has been executed successfully
-------------keep on searching after i write the cert
Old 09-21-2016, 13:32   #5 (permalink)
Member: 2340054
can you tell me how yo root the device
sorry for bad english
plese help !!
Old 09-21-2016, 13:48   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
You can try to root the phone with CF Auto Root.
Old 09-22-2016, 10:15   #7 (permalink)
Member: 2627268
Will this method work with the new security if I use octopus v 2.3.6
Old 09-22-2016, 10:42   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Samsung closed "hole" in latest firmwares. If your phone has one of the latest firmwares - You might need to downgrade it (write older by release date firmware).
Old 09-22-2016, 10:46   #9 (permalink)
Member: 2627268
EPF1 can not be downgraded. Phone is updated to PH2 so, there's now way I can go back to 5.1.1 or even 6.0.1 (first build).
I am stuck at EPH2. What's the solution? Imei is : 3500000000006. Baseband is OK. SN is OK. DRK is damaged, need to reinstall it.
Old 10-12-2016, 05:06   #10 (permalink)
Member: 644540
hello friend excuse my imprudence but could you help me with the certificate I have a sansumg that came uncertificated thank you very much
Old 10-12-2016, 08:02   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
All Cert files, which we have at the moment, are available in "Samsung/For unlock and repair/Certificates" folder of the Support Area (Cert files compatibility).
To enter Support Area, press "Go to support" button on "Support & options" tab of the Software.
Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area.
Old 10-15-2016, 09:22   #12 (permalink)
Member: 2274471
Sonork: 100.1676240
Thanks Meter: 31
INFO : 10/10/2016 4:01:15 PM > Platform: Samsung Android
INFO : 10/10/2016 4:01:15 PM > Selected port: COM1
INFO : 10/10/2016 4:01:15 PM > Selected model: SM-G920T1
INFO : 10/10/2016 4:01:19 PM > Selected file: C:\Users\ahmedraza\Downloads\cert-sm-g920t1_359358060217212_r58g31f192f(2).cert
INFO : 10/10/2016 4:01:20 PM > Detected phone model: SM-G920T1
INFO : 10/10/2016 4:01:20 PM > Firmware compiled date: Thu Jul 7 17:20:02 KST 2016
INFO : 10/10/2016 4:01:20 PM > PDA version: G920T1UVS4EPG2
INFO : 10/10/2016 4:01:20 PM > CSC version: G920T1TMB4EPG2
INFO : 10/10/2016 4:01:20 PM > SW version: G920T1UVS4EPG2
INFO : 10/10/2016 4:01:21 PM > Phone SN: RF1D45EJGGR
INFO : 10/10/2016 4:01:21 PM > Android version: 6.0.1 (MMB29K)
INFO : 10/10/2016 4:01:21 PM > Sales code: TMB
INFO : 10/10/2016 4:01:21 PM > Country: USA
INFO : 10/10/2016 4:01:21 PM > HW platform: exynos5
INFO : 10/10/2016 4:01:21 PM > HW Chip: exynos7420
INFO : 10/10/2016 4:01:21 PM > HW Modem: SHANNON333
INFO : 10/10/2016 4:01:21 PM > Codename: zerofltemtr
INFO : 10/10/2016 4:01:21 PM > Checking Root:
INFO : 10/10/2016 4:01:21 PM > Phone is Rooted.
INFO : 10/10/2016 4:01:21 PM > Reading security backup, please wait...
INFO : 10/10/2016 4:01:56 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920T1-Unknown10-10-2016_16-01-19-.asec file
INFO : 10/10/2016 4:01:56 PM > Checking Certificate file...
INFO : 10/10/2016 4:01:56 PM > Certificate file successfully checked
INFO : 10/10/2016 4:02:00 PM > Deactivating MSL...
INFO : 10/10/2016 4:02:10 PM > Executing exploit...
ERROR : 10/10/2016 4:05:54 PM > Executing exploit failed
ERROR : 10/10/2016 4:05:54 PM > Writing Certificate failed
INFO : 10/10/2016 4:05:54 PM > Performed by 2.3.8 Software version.
Old 10-15-2016, 10:16   #13 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to reflash the phone with older (by release date) firmware, then repeat "Write Cert" operation.
Old 10-16-2016, 16:48   #14 (permalink)
Member: 2274471
Sonork: 100.1676240
Thanks Meter: 31
can u plz help me . my problem still not solved ,
Old 10-17-2016, 08:01   #15 (permalink)
Member: 1146942
Sonork: 100.1587278
Did You try what we've suggested You in previous post? Post here full Software logs of performed operations.
Page generated in 0.43585 seconds with 9 queries
