03-28-2015, 21:02 | #1 (permalink) |
Crazy Poster Join Date: Sep 2014 Location: Cuiabá MT - Brasil
Member: 2257134 Status: Offline Thanks Meter: 1 | Help Repair imei Samsung S5 - G900M [Solved] Ai me the following error appears; Proper android device not found. Make shure that "USB debugging" option on the device is turned on. Operation was failed! The USB debugging is already active, bad no use. I've only had downloaded and installed a firmware support, to see if solved, and nothing happened. Octopus, need help, please. I'm waiting. Thank you, now. Last edited by Octopus box; 04-07-2015 at 06:19. |
03-29-2015, 08:55 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. Please disconnect all other devices from PC, re-install the latest drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe), install the latest Software version (Software), re-boot the PC, re-start the phone, read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info, we will look and try to advise You, what to do the next. |
03-29-2015, 14:36 | #4 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2201001 Status: Offline Thanks Meter: 0 | Good Morning Octopus i have the same issue with G900T Lollipop 5.0. with out root the box connect bout after root start the issue ... Proper android device not found. Make shure that "USB debugging" option on the device is turned on. Operation was failed! |
03-29-2015, 20:57 | #6 (permalink) |
Member: 2201001 Status: Offline Thanks Meter: 0 | With out RootWelcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Dec 01 2014 Firmware compiled time: 23:00:00 Firmware released date: Feb 7 2015 Firmware released time: 11:23:36 SW Version: MPSS.DI.2.0.1.c2-00114-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 |
03-29-2015, 21:43 | #8 (permalink) |
Member: 2201001 Status: Offline Thanks Meter: 0 | With Root Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Dec 01 2014 Firmware compiled time: 23:00:00 Firmware released date: Feb 7 2015 Firmware released time: 11:23:36 SW Version: MPSS.DI.2.0.1.c2-00114-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info, please wait... ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. |
03-29-2015, 21:47 | #9 (permalink) |
Member: 2201001 Status: Offline Thanks Meter: 0 | Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Platform: Samsung Android Selected port: COM15 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM-G900T__00000000000.cert Proper android device not found. Make shure that "USB debug" option on the device is turned on. Certificate has been written successfully Please, restart the phone to apply changes |
03-29-2015, 23:26 | #10 (permalink) |
Member: 2201001 Status: Offline Thanks Meter: 0 | http://forum.gsmhosting.com/vbb/f684...-step-1932215/ Some User have the Same Issue.... |
03-30-2015, 02:11 | #11 (permalink) |
Banned Join Date: Mar 2015
Member: 2370480 Status: Offline Thanks Meter: 6 | If you look at his log you can see that dm mode is already enabled. the problem is when you go to write cert via usb after octopus reads the phone info it just stops. we need solution to write cert via usb on 5.0 phones. |
The Following User Says Thank You to gsm89101 For This Useful Post: |
03-30-2015, 07:48 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Quote:
1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. and repeat "Write Cert" operation again. | |
03-30-2015, 08:43 | #13 (permalink) |
Member: 2370480 Status: Offline Thanks Meter: 6 | Platform: Samsung Android Selected port: COM14 Selected model: SM-G900T Selected file: C:\Users\Luis\Desktop\MEGA Downloads\Cert-SM- G900T_352558067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 If you notice he has dm mode enabled on com14. however anytime you try to write the cert to a 5.0 phone that already has efs wiped and dm mode enable via cp logging when you click write cert on octopus software it reads the pda, csc and sw versions then just stops and does nothing else. how can we fix this? |
03-30-2015, 08:46 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Re-install the latest drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe), perform steps 1-10 again and repeat. |
03-30-2015, 09:09 | #15 (permalink) |
Member: 2370480 Status: Offline Thanks Meter: 6 | I uninstalled samsung drivers then rebooted pc then reinstalled samsung 1.5.45.0 drivers and still doing the same thing. It will read the PDA, CSC and SW Versions of phone and then octopus software just stops. |
