05-03-2014, 11:46 | #33 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do the next: 1. Install the latest Software version (Software). 2. Root the phone. 3. Make backups of Security, EFS and NVM ("Read Security", "Read EFS" and "Read NVM" buttons in Software). 4. Perform the Unlock operation. 5. Perform Repair IMEI operation (select service IMEI from the Software list). 6. Write here the result. |
05-03-2014, 13:13 | #34 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2125685 Status: Offline Thanks Meter: 0 | Hi , I'm trying to try to fix the phone but it makes this error when I try to do any operation to read: Platform: Samsung Android Selected port: COM4 Selected model: SM-N9005 Proper Android device not found. Make shure That "USB debugging" option on the device is turned on. Reading security failed. I have the phone rooted and usb debugging active |
05-12-2014, 00:35 | #37 (permalink) |
Member: 2125685 Status: Offline Thanks Meter: 0 | re Hi , I'm trying to try to fix the phone but it makes this error when I try to do any operation to read: Platform: Samsung Android Selected port: COM4 Selected model: SM-N9005 Proper Android device not found. Make shure That "USB debugging" option on the device is turned on. Reading security failed. I'm not set the diag config, it tells me on the screen of your phone after typing *#9090#; diag config not supported I have the phone rooted and usb debugging active |
05-12-2014, 06:54 | #38 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
08-23-2014, 04:33 | #40 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2245040 Status: Offline Thanks Meter: 0 | Hi there I am new in this forum and i just repair imei from galaxy note 3 SM-900T(tmobile usa) and SM-900A(at&t usa) all has success for repair imei , phone and data work after repair imei. This is what i want ask with octopus about my problem 1.) Before changed imei for note 3,i found some imei from octopus box has blacklist when i checked before i fix imei with octopus and i don't have option to put imei by self from the software like repair imei for galaxy s4. 2.) after i changed imei and i want to unlock the phone and after unlock succesfuly i check again the imei has changed randomly by octopus box and the bad thing is if we get imei that already blacklist than i need to repair imei again,it's look like the network has detect the imei number because the people has used that imei more and more with same imei and when they used the phone and register with the network it show that imei has duplicate and it maybe more than 10 time and i believe that the reason imei has blacklist or in limbo. 3.) is that possible to remove start logo like at&t or tmobile logo by octopus? Thank you |
08-23-2014, 04:58 | #41 (permalink) |
Insane Poster Join Date: Aug 2011 Location: Houston
Member: 1632138 Status: Offline Thanks Meter: 10 | Hey I successfully repaired an imei on a note 3 n900t but for some reason it keep saying searching so I did but another imei it would do exactly same thing. I have didn't few note 3 in the past which worked perfectly fine. Thanks |
08-23-2014, 08:15 | #42 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @widjaja78: 1) Currently only "Repair to Service IMEI" operation is supported for Note 3 phones. 2) Software list of Service IMEIs includes all possible service IMEIs for particular phone. Unfortunately, there is no other service IMEIs, than that which are already in list. 3) Start logo like AT&T or T-Mobile is part of firmware. Writing non branded firmware should remove brand's start logo. @njdevil90: make "Repair 3G/4G" and check network. Try to write different service IMEIs. |
08-26-2014, 06:28 | #44 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ salmanaman Please upload somewhere full Software log and post here link. Also You can send us Software log to PM. We will check it and say to You where can be the problem. |
