02-20-2014, 21:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2101398 Status: Offline Thanks Meter: 8 | Help SGH-I527 imei repair |
02-20-2014, 21:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please post here software log of Repair IMEI operation. Also please make Factory Reset and re-flash the phone with firmware from Support Area. Then do the next: 1. Install the latest Software version (Software). 2. Take out SIM and SD cards from the device. 3. Repeat "Repair IMEI" operation. 4. To finish the operation, restart the phone via phone's menu, don't disconnect the battery, this is important. 5. Write here the result. |
02-20-2014, 22:16 | #5 (permalink) |
Member: 2101398 Status: Offline Thanks Meter: 8 | Here it is To connect SGH-I527 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM111 Selected model: SGH-I527 Mode: Normal Phone model: SGH-I527 Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 3 2013 Firmware released time: 17:21:36 Phone IMEI: xxxxxxxxxx SW version: M8930B-AAAATAZM-5.0.060077 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM111 Selected model: SGH-I527 Mode: Normal Phone model: SGH-I527 Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 3 2013 Firmware released time: 17:21:36 SW version: M8930B-AAAATAZM-5.0.060077 Old IMEI: xxxxxxxxxxxxx New IMEI: xxxxxxxxxxxxxx Creating NVM backup Reading NVM done! Firmware compiled date: Sat Aug 3 16:34:41 KST 2013 PDA version: I527UCUAMH1 CSC version: I527ATTAMH1 SW version: I527UCUAMH1 Phone IMEI: 357742050279328 Phone SN: R34A3254CMY Android version: 4.2.2 (JDQ39) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I527-357742050279328-20-02-2014_13-21- 36-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Aug 3 2013 Firmware released time: 17:21:36 SW version: M8930B-AAAATAZM-5.0.060077 Found phone on COM111 Repairing NVM for SGH-I527 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
02-21-2014, 08:09 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Make "Factory data reset" and re-flash the phone with firmware from Support Area, then perform steps 1-5 once again. When "Repair IMEI" operation will be successfully completed, You should restart the phone via phone's menu, don't disconnect the battery, this is important! |
02-21-2014, 20:37 | #8 (permalink) |
Member: 2101398 Status: Offline Thanks Meter: 8 | Same results. Factory reset then reflash .oct then root and carry on. IMEI did NOT change. Anyone can Help???????????????????????/ Selected port: COM111 Selected model: SGH-I527 Mode: Normal Phone model: SGH-I527 Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 4 2013 Firmware released time: 17:49:10 Phone IMEI: 357742-05-027932-8 SW version: M8930B-AAAATAZM-5.0.060077 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM111 Selected model: SGH-I527 Mode: Normal Phone model: SGH-I527 Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 4 2013 Firmware released time: 17:49:10 SW version: M8930B-AAAATAZM-5.0.060077 Old IMEI: xxxxxxxxxxx New IMEI: xxxxxxxxxxxx Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Mon Nov 4 17:05:30 KST 2013 PDA version: I527UCUAMK2 CSC version: I527ATTAMK2 SW version: I527UCUAMK2 Phone IMEI: 357742050279328 Phone SN: R31D8029CMY Android version: 4.2.2 (JDQ39) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I527-357742050279328-21-02-2014_13-09- 23-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jul 09 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 4 2013 Firmware released time: 17:49:10 SW version: M8930B-AAAATAZM-5.0.060077 Found phone on COM111 Repairing NVM for SGH-I527 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
02-24-2014, 01:42 | #10 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Calgary
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | Try to find NVM file from backup folder look at the time find the first one ( the earilest one) that is the original NVM backup write the NVM file to the phone to see what happen try to read (backup) the NVM file by yourself before unlock the phone it is very important to unlock thoes phones have new securuty. when things go wrong, you have the chance to witre the NVM file back to the phone. Last edited by jason557; 02-24-2014 at 01:49. |
02-24-2014, 19:27 | #11 (permalink) | |
Member: 2101398 Status: Offline Thanks Meter: 8 | Thumbs Quote:
