05-29-2014, 22:32 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2191532 Status: Offline Thanks Meter: 0 | Help: SGH-T879 IMEI FIX ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-T879 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM11 Mode: Normal Phone connection failed Connecting to phone on COM12 Phone connection failed Connecting to phone on COM13 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM2 Phone connection failed Connecting to phone on COM10 Phone connection failed ----------------------------------------------------------------------------------- Since i717 is similar, I picked this model and press the read... ----------------------------------------------------------------------------------- To connect SGH-I717 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I717 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM11 Mode: Normal Phone connection failed Connecting to phone on COM12 Phone connection failed Connecting to phone on COM13 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM2 Phone connection failed Connecting to phone on COM10 Phone connection failed |
05-30-2014, 06:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Your device was detected by Software as "AAABQOCZ", not as "SGH-I717". Do the next: select COM port manually, select device model, check (select) "Manual select" options in Software and try again. |
