03-31-2014, 15:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1092372 Status: Offline Thanks Meter: 32 | help sm -n900 unlock problem ----------------------------------------------------------------------------------- To con[nect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Repairing network failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900 Detected phone model: SM-N900 Firmware compiled date: Wed Oct 30 16:43:33 KST 2013 PDA version: N900XXUCMJ7 CSC version: N900OLBCMJ3 SW version: N900DXUCMJ3 Phone IMEI: 357507050099996 Phone SN: RF1D944VR1X Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900-31-03-2014_19-19-01-.asec file Repairing Network. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait 1-2 minutes. 3. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Repairing Network... Network is successfully repaired. Please, restart phone to apply changes. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900 Detected phone model: SM-N900 Firmware compiled date: Wed Oct 30 16:43:33 KST 2013 PDA version: N900XXUCMJ7 CSC version: N900OLBCMJ3 SW version: N900DXUCMJ3 Phone IMEI: 000000000000000 Phone SN: RF1D944VR1X Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900-31-03-2014_19-25-24-.asec file Repairing Network. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait 1-2 minutes. 3. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Repairing Network... Network is successfully repaired. Please, restart phone to apply changes. [/COLOR] 1st try the imei is ok but network not unlock and then 2nd attempt my imei comes to 000000000000000 default what the procedr to change my imei help octopus team |
03-31-2014, 15:23 | #3 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. I can't see here Software log with Unlock operation. Please post it here also. Also, always read attentively software messages which appear in Software when You make Repair Network for this device: Quote:
