04-23-2014, 18:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | help unlock T889 security failed,unlock failed Code: Welcome to Octoplus/Octopus Box Samsung software version 1.5.4 ----------------------------------------------------------------------------------- To connect SGH-T889 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Emergency Unlock for SGH-T889 phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Emergency Unlock for SGH-T889 phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Emergency Codes for SGH-T889 phone in emergency mode can’t be read ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Emergency Unlock for SGH-T889 phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM20 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM20 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Normal Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Mode: Normal Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- To connect SGH-T889 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T889 Port is busy Mode: Emergency NVM can’t be read for SGH-T889 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Reading phone unlock codes. It can take some time, please wait... Reading security failed Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Unlocking phone... Reading security failed Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Reading phone unlock codes. It can take some time, please wait... Reading security failed Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Unlocking phone... Reading security failed Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Reading NVM... Reading NVM done! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Unlocking phone... Reading security failed Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Reading phone unlock codes. It can take some time, please wait... Reading security failed Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T889 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Reading phone unlock codes. It can take some time, please wait... Reading security failed Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 13:19:39 Phone IMEI: 354340-05-308316-0 SW version: M9615ACEHWMAZD179709 Unlocking phone... Reading security failed Phone unlocking failed |
04-23-2014, 18:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. There is new (currently not supported) security type in your device. Please, read full flash from your phone by using "Read Full SGH-T889.bat" file inside of this package (https://mega.co.nz/#!r5JHTSgD!-XqfA-...Cn7CQ1lhGHDEJk). 4 files will be read, pack them, upload somewhere and post here link. We will research and prepare test Software version for You. |
04-24-2014, 06:28 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Disconnect all devices from your PC, re-start the PC, connect your SGH-T889, turn on USB Debugging Mode, install ADB drivers and try to read Full flash again. |
04-25-2014, 06:23 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As I see, your phone is not connected correctly. There is no proper device in PC Device Manager. To read full flash, You need to root the phone manually, turn on USB Debugging Mode in the phone, connect the phone to PC, install Android ABD driver and then read full flash by using mentioned above *.bat file. |
04-26-2014, 08:12 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Turn on USB Debugging Mode, then connect the phone to PC and install ADB driver, as a result, Android ABD Interface device should appears in PC Device Manager. |
04-26-2014, 10:49 | #9 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
i was do the same enable usb debugging but no ADB driver ask to install or appears on pc device manager , all driver from supported already installed | |
04-28-2014, 05:00 | #11 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | here the four files (https://mega.co.nz/#fm/bkJlECCI) |
04-28-2014, 12:44 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We have prepared and sent You test Software version into PM. Please try to perform Unlock operation by using this Software and post here the result. |
