10-09-2018, 07:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | How to fix software repair assistant [Answered] Welcome to Octoplus Box Samsung software version 2.7.3 ----------------------------------------------------------------------------------- To connect SM-N910P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: N910VVRU2BOG5_N910VVZW2BOG5 _VZW_Android_5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. After flash it showing that YOUR DEVICE DIDNT START UP SUCCESSFULLY. USE THE BVERIZON SOFTWARE REPAIR ASSISTANT ON A COMPUTER TO REPAIR YOUR DEVICE . Plz guide me how to fix it ,,,this warning i looking first time ,,never had it before. Last edited by Octopus box; 10-09-2018 at 08:30. |
