12-18-2014, 14:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | How to flash gt s6812? To put GT-S6812 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Please select firmware with PIT Writing Firmware Failed Please put the phone into Download Mode and connect USB cable. To put GT-S6812 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Please select firmware with PIT Writing Firmware Failed ONLY ONE FIRMWARE IS AVAILABLE AT SUPPORT SITE |
12-18-2014, 15:37 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is the problem with your phone exactly? Why do You want to re-flash it? This error means, that there can be the problem with phone's flash chip: Quote:
12-18-2014, 16:02 | #3 (permalink) | |
Member: 608370 Status: Offline Thanks Meter: 89 | Quote:
its bluetooth and wifi not working and restarts after sometimes | |
12-18-2014, 17:47 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have uploaded another one firmware for this device into the Support Area. Try to write this firmware, unfortunately, currently we have no PIT file for this device. |
12-19-2014, 10:46 | #5 (permalink) | |
Selected firmware file: S6812DDAMD3_S6812OJVAMD2 _S6812ODDAMD1.oct Please put the phone into Download Mode and connect USB cable. To put GT-S6812 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed same problem with uploaded firmware | |
12-19-2014, 11:04 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You should try to write firmware with PIT. Unfortunately, currently we have no PIT file for this device. As soon as we will have PIT for this device we will upload it into the Support Area. Also, your device can has HW issue. Maybe someone have PIT file for this phone and upload it here for You. |
