12-02-2013, 15:56 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | how to flash i9100 to 4.1.2 I have the set with 2.3.5 firmware details i9100 jpkj2 i9100 xxki4 i9100 ojpkj1 build infor : thu oct 1313:50:39 kst 2011 Also sales code is CHN now I want to flash this set to 4.1.2. which firmware need to flash this set bro. because i had a problem on logo when i try to update it via Odin .then I will use m250s or m250k firmware from support to recover the set. but after that phone is on koriyan...also can not convert to i9100 after that if I connect to kies Uploaded with ImageShack.us But phone original i9100 (back side sticker and inside firmware are i9100) So could you please advice me to update this set 4.1.2. Thanks. |
12-04-2013, 08:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, try to write firmware with Android 4.1.2 from the Support Area and post the result here. Don't forget to make EFS, Security and NVM backups before to write firmware. |
12-04-2013, 09:32 | #5 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
In 4.1.2 there is no "JP" county code firmware So which one I want to flash bro? Thanks. | |
12-04-2013, 09:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | All firmwares we have for this device are in the Support Area. If You need some another firmware, please try to search original firmware, convert it by using Firmware Convertor and then write it into your phone. |
12-04-2013, 14:55 | #7 (permalink) | |
JP firmware there is no 4.1.2 ...it is only 4.0.4 this thread aim is to flash 4.1.2 firmware but I don't know which firmware i want to Select thanks. | |
