01-05-2013, 15:27 | #1 (permalink) |
Freak Poster Join Date: May 2011
Member: 1583861 Status: Offline Thanks Meter: 13 | plz help octopus team i9100 big problem but hang on glaxy logo plz help team Welcome to Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Selected firmware file: GT-I9100_XXKG1_rooted(1).oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing DATAFS section... Writing Firmware Failed |
01-05-2013, 19:38 | #2 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | You have a phone with emmc brick bug problem. You need to write the firmware with Odin and a special PIT file which can repeire this problem. It is not an easy task. |
01-06-2013, 07:08 | #5 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | Quote:
u1_02_20110310_emmc_EXT4 - Download - 4shared Odin3-v1.85 - Download - 4shared | |
01-06-2013, 09:14 | #6 (permalink) |
Member: 1722871 Status: Offline Thanks Meter: 116 | That files will not help you in that situation. Search on XDA for the special pit files to see the tutorial and everything. I don't have the link on the phone. Sent from my GT-I9300 using Tapatalk 2 |
01-08-2013, 07:54 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ zaidi_mobile Hello. What was the problem with your phone from the beginning before You have tried to write firmware? What was the firmware version in your phone? Have You tried to write different firmwares? |
01-08-2013, 08:39 | #9 (permalink) |
Member: 1583861 Status: Offline Thanks Meter: 13 | start phone still hang glaxy logo then i write different firmware versions is given below I9100GJPLPB_OJPLP7_Arabic_Android_4.0.4 I9100GJPLPB_I9100GOJPLP7_I9100GXXLPV_HOME.tar.md5 I9100XXLP6_OXXLP3_Android_4.0.3 |
