04-05-2015, 07:37 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | how to flash unlock and repair imei sm-b360e [Solved] here is log and screen shoot Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect GT-S8530 phone you have to perform the following steps: 1. Go to dial window. 2. Enter "*#197328640#" number. 3. Make next steps: select Common->Service configuration->Data service confing->USB ACM AP. 4. Restart phone. 5. Press "Read Info" in software. Selected firmware file: B360E_XXNK5_OXEANL1.oct ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM8 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM8 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM8 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Sending mainloader Failed Last edited by Octopus box; 11-26-2015 at 11:20. |
04-05-2015, 09:02 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Re-install drivers, fully charge phone's battery before. Press and hold "1" button more longer while connecting. Try to connect the phone several times. |
04-07-2015, 11:19 | #4 (permalink) |
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | i try new pc fresh window full charge battery ...fllow all instrcttion but alway show same error plsss help me urjently thanks in advanced Last edited by Octopus box; 04-07-2015 at 13:26. |
04-07-2015, 13:26 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Contact us to Skype or ICQ, we will look remotely via Team Viewer, where can be the problem with your phone. Our contacts You can find in our profile. |
06-07-2015, 10:45 | #6 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | i have same problem, how to flash & unlock. 1. Samsung_spreadtrum_driver_x64_x86.rar Install driver, i have win 64. so i use this. 2. Press and hold "1" button Without Battery after boot put battery. 3. now u do job, :-) Quote:
The Following User Says Thank You to naveed ali For This Useful Post: |
09-28-2015, 12:10 | #7 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | SM-B360E flashing done Hi there Samsung SM-B360E flashing is very painful but it done by the following procedure 1)download these two flasher:ResearchDownload - Download - 4shared - m.s. khan firmware:https://drive.google.com/file/d/0Bw2...eEk/view?pli=1 After flashing success U can't see the complete function in the phone and keypad number also Now Download this file from octopus server b360e_xxnl3_oxeanl3.oct Now once again flash the phone by octopus box and now octopus box will flash the phone completely In this time ur phone will be perfect Enjoy Here is the success report log: Quote:
The Following 2 Users Say Thank You to M.S.khan For This Useful Post: |
11-26-2015, 10:22 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone with any firmware from the Support Area. Post here result and full Software log of the operation. |
12-16-2015, 09:31 | #11 (permalink) | |
Junior Member Join Date: Nov 2013
Member: 2075571 Status: Offline Thanks Meter: 3 | Quote:
problam solved thanks...................... | |
01-08-2016, 17:03 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do exactly the next: 1. Reflash the phone with original firmware and flashing tool. 2. Reflash the phone with "b360e_xxnl3_oxeanl3" firmware Support Area. Post here the result. |
02-14-2016, 17:10 | #15 (permalink) |
Crazy Poster Join Date: Jan 2011
Member: 1492570 Status: Offline Thanks Meter: 4 | Octopus box samsung b360e sim unlock wast tool+ wast file ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM28 Selected model: SM-B360E Selected port: USB To connect SM-B360E phone perform the following steps: 1. Disconnect phone battery. 2. Press and hold "1" button, connect USB cable. 3. Connect battery. Connecting... Phone found. Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing User section... User section has been written successfully. Writing Res section... Res section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing DSP section... DSP section has been written successfully. Writing HDISK section... HDISK section has been written successfully. Writing UDISK section... UDISK section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. |
