05-22-2014, 18:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | I497 Cant Upgrade to 412 [Solved] i try downgrade to 4.0.4 from support and phone success unlock with branding digitel 4.0.4 but after that i want upgrade again to 4.1.2 at&t but i show error sbl1 failed how to solved it ? |
05-22-2014, 19:16 | #3 (permalink) |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | here log flashing, i cancel bcoz on tab show sbl 1 failed and on software stuck on writing Code: Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\22-05-2014_23-54-50.log" created (22/05/2014 23:54:57). ERROR : 22/05/2014 23:54:57 > Access violation at address 008F0BF0 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 22/05/2014 23:54:58 > Set up system language English (file: English.ini) INFO : 22/05/2014 23:54:58 > Welcome to Octoplus/Octopus Box Samsung software version 1.5.5 INFO : 22/05/2014 23:54:58 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 23:54:58 > To connect SGH-I497 phone you have to perform the following steps: INFO : 22/05/2014 23:54:58 > 1. Disconnect USB cable from phone. INFO : 22/05/2014 23:54:58 > 2. Go to Menu->Settings->Applications->Development. INFO : 22/05/2014 23:54:58 > 3. Turn on "USB Debugging" option. INFO : 22/05/2014 23:54:58 > 4. When message is appear press "Yes". INFO : 22/05/2014 23:54:58 > 5. Go to Calculator application. INFO : 22/05/2014 23:54:58 > 6. Enter "(+30012012732+" number, to get phone dial window. INFO : 22/05/2014 23:54:58 > 7. Enter "*#1575#" number. INFO : 22/05/2014 23:54:58 > 8. On phone keybord press "Menu" button, and select "Back". INFO : 22/05/2014 23:54:58 > 9. Set "Diag config" to "USB" value. INFO : 22/05/2014 23:54:58 > 10. Go to dial window. INFO : 22/05/2014 23:54:58 > 11. Enter "*#7284#" number. INFO : 22/05/2014 23:54:58 > 12. Set "USB" radio button to "PDA" value. INFO : 22/05/2014 23:54:58 > 13. Go to "Qualcomm USB Settings". INFO : 22/05/2014 23:54:58 > 14. Select "MODEM". INFO : 22/05/2014 23:54:58 > 15. Press Home button. INFO : 22/05/2014 23:54:58 > 16. Press "Read Info" in software. INFO : 22/05/2014 23:55:42 > Firmware conversion started for phone INFO : 22/05/2014 23:55:42 > Firmware conversion started for SGH-I497 phone INFO : 22/05/2014 23:59:24 > Firmware converted successfully INFO : 23/05/2014 0:01:51 > Selected firmware file: I497VLAMJ2_I497XACAMJ2_I497VLAMJ2_HOME.oct WARN : 23/05/2014 0:01:59 > Please switch your phone to the download mode and connect it to a PC. WARN : 23/05/2014 0:01:59 > To put SGH-I497 phone into download mode you have to perform the following steps: WARN : 23/05/2014 0:01:59 > 1. Reconnect phone battery. WARN : 23/05/2014 0:01:59 > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 23/05/2014 0:01:59 > 3. When phone turns on press "Volume+" button. INFO : 23/05/2014 0:01:59 > Found phone on INFO : 23/05/2014 0:01:59 > Firmware write started. INFO : 23/05/2014 0:01:59 > Writing SBL1 section... INFO : 23/05/2014 0:02:40 > Writing firmware Canceled Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\22-05-2014_23-54-50.log" closed (23/05/2014 1:01:25). here log read info downgrade 4.0.4 and unlock Code: Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\22-05-2014_14-46-50.log" created (22/05/2014 14:46:57). ERROR : 22/05/2014 14:46:58 > Access violation at address 008F0BF0 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 22/05/2014 14:46:59 > Set up system language English (file: English.ini) INFO : 22/05/2014 14:46:59 > Welcome to Octoplus/Octopus Box Samsung software version 1.5.5 INFO : 22/05/2014 14:46:59 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 14:46:59 > To connect SGH-I497 phone you have to perform the following steps: INFO : 22/05/2014 14:46:59 > 1. Disconnect USB cable from phone. INFO : 22/05/2014 14:46:59 > 2. Go to Menu->Settings->Applications->Development. INFO : 22/05/2014 14:46:59 > 3. Turn on "USB Debugging" option. INFO : 22/05/2014 14:46:59 > 4. When message is appear press "Yes". INFO : 22/05/2014 14:46:59 > 5. Go to Calculator application. INFO : 22/05/2014 14:46:59 > 6. Enter "(+30012012732+" number, to get phone dial window. INFO : 22/05/2014 14:46:59 > 7. Enter "*#1575#" number. INFO : 22/05/2014 14:46:59 > 8. On phone keybord press "Menu" button, and select "Back". INFO : 22/05/2014 14:46:59 > 9. Set "Diag config" to "USB" value. INFO : 22/05/2014 14:46:59 > 10. Go to dial window. INFO : 22/05/2014 14:46:59 > 11. Enter "*#7284#" number. INFO : 22/05/2014 14:46:59 > 12. Set "USB" radio button to "PDA" value. INFO : 22/05/2014 14:46:59 > 13. Go to "Qualcomm USB Settings". INFO : 22/05/2014 14:46:59 > 14. Select "MODEM". INFO : 22/05/2014 14:46:59 > 15. Press Home button. INFO : 22/05/2014 14:46:59 > 16. Press "Read Info" in software. INFO : 22/05/2014 14:50:40 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 14:50:40 > Platform: Samsung Android INFO : 22/05/2014 14:50:40 > Selected port: COM50 INFO : 22/05/2014 14:50:40 > Selected model: SGH-I497 INFO : 22/05/2014 14:50:47 > Phone was not found on the selected port! INFO : 22/05/2014 14:57:35 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 14:57:35 > Platform: Samsung Android INFO : 22/05/2014 14:57:35 > Selected port: COM33 INFO : 22/05/2014 14:57:35 > Selected model: SGH-I497 INFO : 22/05/2014 14:57:36 > Mode: Normal INFO : 22/05/2014 14:57:36 > Phone model: SGH-I497 INFO : 22/05/2014 14:57:36 > Firmware compiled date: May 02 2013 INFO : 22/05/2014 14:57:36 > Firmware compiled time: 04:00:00 INFO : 22/05/2014 14:57:36 > Firmware released date: Jun 8 2013 INFO : 22/05/2014 14:57:36 > Firmware released time: 23:48:45 INFO : 22/05/2014 14:57:36 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 14:57:36 > SW version: M8960A-AAAANAZM-2.0.01092 INFO : 22/05/2014 14:57:40 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 14:57:40 > Platform: Samsung Android INFO : 22/05/2014 14:57:40 > Selected port: COM33 INFO : 22/05/2014 14:57:40 > Selected model: SGH-I497 INFO : 22/05/2014 14:57:40 > Mode: Normal INFO : 22/05/2014 14:57:40 > Phone model: SGH-I497 INFO : 22/05/2014 14:57:40 > Firmware compiled date: May 02 2013 INFO : 22/05/2014 14:57:40 > Firmware compiled time: 04:00:00 INFO : 22/05/2014 14:57:40 > Firmware released date: Jun 8 2013 INFO : 22/05/2014 14:57:40 > Firmware released time: 23:48:45 INFO : 22/05/2014 14:57:40 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 14:57:40 > SW version: M8960A-AAAANAZM-2.0.01092 INFO : 22/05/2014 14:57:40 > Reading phone unlock codes. It can take some time, please wait... ERROR : 22/05/2014 14:57:40 > Reading security failed ERROR : 22/05/2014 14:57:40 > Read codes failed INFO : 22/05/2014 14:57:46 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 14:57:46 > Platform: Samsung Android INFO : 22/05/2014 14:57:46 > Selected port: COM33 INFO : 22/05/2014 14:57:46 > Selected model: SGH-I497 INFO : 22/05/2014 14:57:46 > Mode: Normal INFO : 22/05/2014 14:57:47 > Phone model: SGH-I497 INFO : 22/05/2014 14:57:47 > Firmware compiled date: May 02 2013 INFO : 22/05/2014 14:57:47 > Firmware compiled time: 04:00:00 INFO : 22/05/2014 14:57:47 > Firmware released date: Jun 8 2013 INFO : 22/05/2014 14:57:47 > Firmware released time: 23:48:45 INFO : 22/05/2014 14:57:47 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 14:57:47 > SW version: M8960A-AAAANAZM-2.0.01092 INFO : 22/05/2014 14:57:47 > Unlocking phone... INFO : 22/05/2014 14:57:47 > Creating NVM backup INFO : 22/05/2014 15:18:37 > Reading NVM done! ERROR : 22/05/2014 15:18:37 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 22/05/2014 15:18:37 > Phone unlocking failed INFO : 22/05/2014 15:28:13 > Selected firmware file: I497UMAMA1_I497JDIAMA1_JDI_Android_4.0.4.oct WARN : 22/05/2014 15:32:45 > Please switch your phone to the download mode and connect it to a PC. WARN : 22/05/2014 15:32:45 > To put SGH-I497 phone into download mode you have to perform the following steps: WARN : 22/05/2014 15:32:45 > 1. Reconnect phone battery. WARN : 22/05/2014 15:32:45 > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 22/05/2014 15:32:45 > 3. When phone turns on press "Volume+" button. INFO : 22/05/2014 15:32:46 > Found phone on INFO : 22/05/2014 15:32:46 > Firmware write started. INFO : 22/05/2014 15:32:46 > Writing ABOOT section... INFO : 22/05/2014 15:32:49 > ABOOT section has been written successfully. INFO : 22/05/2014 15:32:49 > Writing RPM section... INFO : 22/05/2014 15:32:51 > RPM section has been written successfully. INFO : 22/05/2014 15:32:51 > Writing SBL1 section... INFO : 22/05/2014 15:32:53 > SBL1 section has been written successfully. INFO : 22/05/2014 15:32:53 > Writing SBL2 section... INFO : 22/05/2014 15:32:56 > SBL2 section has been written successfully. INFO : 22/05/2014 15:32:56 > Writing SBL3 section... INFO : 22/05/2014 15:32:58 > SBL3 section has been written successfully. INFO : 22/05/2014 15:32:58 > Writing TZ section... INFO : 22/05/2014 15:33:00 > TZ section has been written successfully. INFO : 22/05/2014 15:33:00 > Writing BOOT section... INFO : 22/05/2014 15:33:05 > BOOT section has been written successfully. INFO : 22/05/2014 15:33:05 > Writing RECOVERY section... INFO : 22/05/2014 15:33:10 > RECOVERY section has been written successfully. INFO : 22/05/2014 15:33:10 > Writing SYSTEM section... INFO : 22/05/2014 15:38:51 > SYSTEM section has been written successfully. INFO : 22/05/2014 15:38:51 > Writing CACHE section... INFO : 22/05/2014 15:39:03 > CACHE section has been written successfully. INFO : 22/05/2014 15:39:03 > Writing HIDDEN section... INFO : 22/05/2014 15:39:06 > HIDDEN section has been written successfully. INFO : 22/05/2014 15:39:06 > Writing MODEM section... INFO : 22/05/2014 15:39:27 > MODEM section has been written successfully. INFO : 22/05/2014 15:39:27 > Firmware writing successfully completed. INFO : 22/05/2014 15:57:18 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 15:57:18 > Platform: Samsung Android INFO : 22/05/2014 15:57:18 > Selected port: COM1 INFO : 22/05/2014 15:57:18 > Selected model: SGH-I497 INFO : 22/05/2014 15:57:24 > Mode: Emergency ERROR : 22/05/2014 15:57:24 > Codes for SGH-I497 phone in emergency mode can’t be read WARN : 22/05/2014 15:57:24 > Reading codes canceled INFO : 22/05/2014 15:57:32 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 15:57:32 > Platform: Samsung Android INFO : 22/05/2014 15:57:32 > Selected port: COM52 INFO : 22/05/2014 15:57:32 > Selected model: SGH-I497 INFO : 22/05/2014 15:57:32 > Mode: Normal INFO : 22/05/2014 15:57:32 > Phone model: SGH-I497 INFO : 22/05/2014 15:57:32 > Firmware compiled date: Aug 22 2012 INFO : 22/05/2014 15:57:32 > Firmware compiled time: 09:00:00 INFO : 22/05/2014 15:57:32 > Firmware released date: Jan 4 2013 INFO : 22/05/2014 15:57:32 > Firmware released time: 22:26:58 INFO : 22/05/2014 15:57:33 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 15:57:33 > SW version: M8960A-AAAANAZM-2.0.01045 INFO : 22/05/2014 15:57:34 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 15:57:34 > Platform: Samsung Android INFO : 22/05/2014 15:57:34 > Selected port: COM52 INFO : 22/05/2014 15:57:34 > Selected model: SGH-I497 INFO : 22/05/2014 15:57:34 > Mode: Normal INFO : 22/05/2014 15:57:34 > Phone model: SGH-I497 INFO : 22/05/2014 15:57:34 > Firmware compiled date: Aug 22 2012 INFO : 22/05/2014 15:57:34 > Firmware compiled time: 09:00:00 INFO : 22/05/2014 15:57:34 > Firmware released date: Jan 4 2013 INFO : 22/05/2014 15:57:34 > Firmware released time: 22:26:58 INFO : 22/05/2014 15:57:34 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 15:57:34 > SW version: M8960A-AAAANAZM-2.0.01045 INFO : 22/05/2014 15:57:34 > Reading phone unlock codes. It can take some time, please wait... INFO : 22/05/2014 15:57:35 > Connecting to server... INFO : 22/05/2014 15:57:36 > Connect successfully to server INFO : 22/05/2014 15:57:36 > Checking smart card... INFO : 22/05/2014 15:57:38 > Smart card successfully checked INFO : 22/05/2014 15:57:39 > Checking operation... INFO : 22/05/2014 15:57:39 > Operation successfully checked WARN : 22/05/2014 15:57:39 > NCK unlock code: *#7465625*638*79315372# WARN : 22/05/2014 15:57:39 > NSCK unlock code: *#7465625*782*00000000# WARN : 22/05/2014 15:57:40 > SPCK unlock code: *#7465625*77*00000000# INFO : 22/05/2014 16:14:32 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 16:14:32 > Platform: Samsung Android INFO : 22/05/2014 16:14:32 > Selected port: COM52 INFO : 22/05/2014 16:14:32 > Selected model: SGH-I497 INFO : 22/05/2014 16:14:32 > Mode: Normal INFO : 22/05/2014 16:14:32 > Phone model: SGH-I497 INFO : 22/05/2014 16:14:33 > Firmware compiled date: Aug 22 2012 INFO : 22/05/2014 16:14:33 > Firmware compiled time: 09:00:00 INFO : 22/05/2014 16:14:33 > Firmware released date: Jan 4 2013 INFO : 22/05/2014 16:14:33 > Firmware released time: 22:26:58 INFO : 22/05/2014 16:14:33 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 16:14:33 > SW version: M8960A-AAAANAZM-2.0.01045 INFO : 22/05/2014 16:14:35 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 16:14:35 > Platform: Samsung Android INFO : 22/05/2014 16:14:35 > Selected port: COM52 INFO : 22/05/2014 16:14:35 > Selected model: SGH-I497 INFO : 22/05/2014 16:14:35 > Mode: Normal INFO : 22/05/2014 16:14:35 > Phone model: SGH-I497 INFO : 22/05/2014 16:14:35 > Firmware compiled date: Aug 22 2012 INFO : 22/05/2014 16:14:35 > Firmware compiled time: 09:00:00 INFO : 22/05/2014 16:14:35 > Firmware released date: Jan 4 2013 INFO : 22/05/2014 16:14:35 > Firmware released time: 22:26:58 INFO : 22/05/2014 16:14:35 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 16:14:35 > SW version: M8960A-AAAANAZM-2.0.01045 INFO : 22/05/2014 16:14:35 > Unlocking phone... INFO : 22/05/2014 16:14:37 > Phone is successfully unlocked WARN : 22/05/2014 16:14:37 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) INFO : 22/05/2014 16:16:07 > ----------------------------------------------------------------------------------- INFO : 22/05/2014 16:16:07 > Platform: Samsung Android INFO : 22/05/2014 16:16:07 > Selected port: COM52 INFO : 22/05/2014 16:16:07 > Selected model: SGH-I497 INFO : 22/05/2014 16:16:07 > Mode: Normal INFO : 22/05/2014 16:16:07 > Phone model: SGH-I497 INFO : 22/05/2014 16:16:07 > Firmware compiled date: Aug 22 2012 INFO : 22/05/2014 16:16:07 > Firmware compiled time: 09:00:00 INFO : 22/05/2014 16:16:07 > Firmware released date: Jan 4 2013 INFO : 22/05/2014 16:16:07 > Firmware released time: 22:26:58 INFO : 22/05/2014 16:16:07 > Phone IMEI: 353488-05-113643-0 INFO : 22/05/2014 16:16:07 > SW version: M8960A-AAAANAZM-2.0.01045 INFO : 22/05/2014 16:16:07 > Creating NVM backup INFO : 22/05/2014 16:18:25 > Reading NVM done! INFO : 22/05/2014 16:18:25 > Repairing NVM for SGH-I497 phone... INFO : 22/05/2014 16:18:33 > NVM repair completed successfully WARN : 22/05/2014 16:18:33 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\22-05-2014_14-46-50.log" closed (22/05/2014 16:30:41). |
