Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-17-2013, 14:47   #1 (permalink)
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 15
how to imei repair i9190
how to imei repair i9190 help please
Old 08-17-2013, 15:36   #2 (permalink)
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 15
octopus box added today
Old 08-19-2013, 08:35   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 6,543
Hello.
Yes, please root the phone and make Repair IMEI. Then post the result here.
Read carefully software manual before.
Old 08-19-2013, 14:13   #4 (permalink)
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 15
I did root the phone, but the following article I chose usb debugging turns out I opened the com
To put the phone into download mode GT-I9190 you have to perform the
not following steps:
1 Reconnect phone battery.
2 Press and hold the "Volume -" + "Home" + "Power" buttons.
3 Phone turns on when I press the "Volume +" button.
Found phone on
Firmware write started.
Writing RECOVERY section ...
RECOVERY section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Android
Selected port: COM81
Selected model: GT-I9190
Mode: Emergency
Old 08-19-2013, 14:20   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 6,543
To connect the phone please perform the next steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#0808#" number.
7. Select "DM+Modem+ADB".
8. Close window.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in software.
Old 08-24-2013, 09:05   #6 (permalink)
Member: 314207
Thanks Meter: 22
i 9190 not work
Selected port: COM88
Mode: Normal
Phone model: GT-I9190
Firmware compiled date: Jun 04 2013
Firmware compiled time: 17:00:00
Firmware released date: Jun 18 2013
Firmware released time: 22:12:36
SW Version: M8930B-AAAATAZM-3.2.27030
Old IMEI: 004400-15-202000-0
New IMEI: 357344-00-xxxxxxxxx
Firmware compiled date: Tue Jun 18 21:11:47 KST 2013
Phone SN: RF1D74PHQNH
Android version: 4.2.2 (JDQ39)
Cheking Root
Erasing old IMEI. It can take some time. Please wait...
Phone will restart now. Please don't disconnect cable!
Found phone on COM88
Repairing NVM for GT-I9190 phone...
NVM repair completed successfully
New IMEI successfully written.
Please, restart the phone to apply changes
Mode: Normal
Incorrect IMEI
Old 08-26-2013, 07:45   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 6,543
What do You mean under "i 9190 not work"? Please explain the problem in more details.
Note, after phone's IMEI was successfully changed You need to re-start the phone via phone's menu (don't disconnect phone's battery!).
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.26941 seconds with 7 queries
