Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-17-2013, 14:47   #1 (permalink)
ancient123's Avatar
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 18
how to imei repair i9190 [Solved]
how to imei repair i9190 help please
Old 08-17-2013, 15:36   #2 (permalink)
ancient123's Avatar
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 18
octopus box added today
Old 08-19-2013, 08:35   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,412
Hello.
Yes, please root the phone and make Repair IMEI. Then post the result here.
Read carefully software manual before.
Old 08-19-2013, 14:13   #4 (permalink)
ancient123's Avatar
Member: 1762177
Sonork: 100.1618338
Thanks Meter: 18
I did root the phone, but the following article I chose usb debugging turns out I opened the com
To put the phone into download mode GT-I9190 you have to perform the
not following steps:
1 Reconnect phone battery.
2 Press and hold the "Volume -" + "Home" + "Power" buttons.
3 Phone turns on when I press the "Volume +" button.
Found phone on
Firmware write started.
Writing RECOVERY section ...
RECOVERY section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Android
Selected port: COM81
Selected model: GT-I9190
Mode: Emergency
Old 08-19-2013, 14:20   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
To connect the phone please perform the next steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#0808#" number.
7. Select "DM+Modem+ADB".
8. Close window.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in software.
Old 08-24-2013, 09:05   #6 (permalink)
Member: 314207
Thanks Meter: 35
i 9190 not work
Selected port: COM88
Mode: Normal
Phone model: GT-I9190
Firmware compiled date: Jun 04 2013
Firmware compiled time: 17:00:00
Firmware released date: Jun 18 2013
Firmware released time: 22:12:36
SW Version: M8930B-AAAATAZM-3.2.27030
Old IMEI: 004400-15-202000-0
New IMEI: 357344-00-xxxxxxxxx
Firmware compiled date: Tue Jun 18 21:11:47 KST 2013
Phone SN: RF1D74PHQNH
Android version: 4.2.2 (JDQ39)
Cheking Root
Erasing old IMEI. It can take some time. Please wait...
Phone will restart now. Please don't disconnect cable!
Found phone on COM88
Repairing NVM for GT-I9190 phone...
NVM repair completed successfully
New IMEI successfully written.
Please, restart the phone to apply changes
Mode: Normal
Incorrect IMEI
Old 08-26-2013, 07:45   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
What do You mean under "i 9190 not work"? Please explain the problem in more details.
Note, after phone's IMEI was successfully changed You need to re-start the phone via phone's menu (don't disconnect phone's battery!).
Old 05-23-2014, 01:11   #8 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
Process done twice but same imei.. It doent change in the phone..
Welcome to Octoplus/Octopus Box Samsung software version 1.5.0
To connect GT-I9190 phone you have to perform the following steps:
2. Go to Menu->Settings->More->About Device.
3.Tap on "Builds numbers" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Close window.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Selected port: COM73
Mode: Normal
Firmware released date: Aug 1 2013
Firmware released time: 17:05:15
Phone IMEI: 357961-05-242991-9
SW version: M8930B-AAAATAZM-3.2.27030
Reading NVM...
NVM reading process failed
Detected phone model: GT-I9190
Firmware compiled date: Thu Aug 1 16:02:46 KST 2013
PDA version: I9190UBUAMH1
CSC version: I9190UUBAMH1
SW version: I9190UBUAMH1
Phone IMEI: 357961052429919
Phone SN: R21D793SNQP
Reading EFS, please wait...
EFS read successfully.
Reading security backup, please wait...
Security read successfully.
Mode: Normal
Old IMEI: 357961-05-242991-9
New IMEI: 358741-05-242991-4
Creating NVM backup
Reading NVM done!
Cheking Root
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-GT-I9190-357961052429919-22-05-2014_19-14-
17-.asec file
Found phone on COM73
IMEI successfully repaired.
To finish the operation, please restart the phone via phone's menu
(don't disconnect the battery!)
Port is busy
Mode: Emergency
Write IMEI failed
Mode: Normal
Mode: Normal
Creating NVM backup
Reading NVM done!
Cheking Root
\BACKUP\Security-GT-I9190-357961052429919-22-05-2014_19-20-
16-.asec file
Old 05-23-2014, 02:34   #9 (permalink)
Member: 594580
Thanks Meter: 157
OK this time all done good, imei repaired after change root files.. Thnaks..
Page generated in 0.25084 seconds with 8 queries
