01-12-2016, 17:24 | #1 (permalink) |
Insane Poster Join Date: May 2012
Member: 1757500 Status: Offline Thanks Meter: 27 | How to remove Fap Lock Samsung S6 Edge I try this but not done so please help me Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock.. Reset operation completed! |
01-12-2016, 17:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please make "Read PIT" and upload received *.pit file to any file-sharing service. Also, Please upload *.log and *.logx of "Reset FRP/Reactivation/EE"operation. Post here download link for these files, we will check what causes the problem. |
01-13-2016, 07:38 | #3 (permalink) |
Member: 1757500 Status: Offline Thanks Meter: 27 | Hello Here is log and all upload file PIT-SM-G925T Logx rar please help me Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Please put the phone into Download Mode and connect USB cable. To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Reading PIT... PIT was read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock.. Reset operation completed! |
01-13-2016, 10:49 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely your phone has new type of Security, which prevents removal of FRP lock. This problem is under research. We will inform You about possible solution. |
01-13-2016, 10:52 | #5 (permalink) | |
Member: 1757500 Status: Offline Thanks Meter: 27 | Quote:
Hello Thanks Can U tell me How Much Time to Wait for this solution Coming ?? Please tell me Any Idea ? | |
01-13-2016, 11:11 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Currently we can't say how long will it take to find a solution, to process SM-G925T phones with new Security type. We will notify You about the solution as soon as it will be found |
