07-01-2013, 07:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please try to make Repair EFS and then re-flash the phone. If the problem will be still the same - currently no software solution for such issue; most likely, this is HW problem (problem with phone's flash chip). |
07-01-2013, 11:57 | #3 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: India
Member: 583492 Status: Offline Thanks Meter: 125 | Quote:
after repairing efs shows this Welcome to Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect GT-I9003 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2 Selected model: GT-I9003 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM247 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM247 Selected model: GT-I9003 Write IMEI failed | |
07-01-2013, 12:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What are the baseband and IMEI in your phone after of Repair EFS? If the problem is still the same - currently no software solution for such issue. |
01-15-2014, 09:28 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to do the next: 1. Make "Repair EFS". 2. Re-flash the device with different firmwares and check, whether phone's Baseband is correct (not Unknown). Also, this can be HW problem. |
04-30-2014, 10:05 | #8 (permalink) |
Junior Member Join Date: May 2010 Location: mumbai
Member: 1299469 Status: Offline Sonork: [email protected] Thanks Meter: 0 | help me samsung 19003 basebang unknown helpme any master maind frien cantact no 9768393133 emailid [email protected] |
