06-07-2014, 23:20 | #2 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: Santiago de Chile
Member: 370221 Status: Offline Sonork: 1592059 Thanks Meter: 97 | Quote:
Regards from chile | |
06-08-2014, 08:42 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | To root the device, try to use the latest versions of VRoot, Kingo Root, Impactor Softwares. |
06-09-2014, 06:50 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
06-09-2014, 16:54 | #6 (permalink) | ||
06-09-2014, 16:58 | #7 (permalink) | |
06-09-2014, 19:49 | #8 (permalink) |
Member: 370221 Status: Offline Sonork: 1592059 Thanks Meter: 97 | Well when I type *#0808# I get the options to change to DM+MODEM+ADB the device said saved 9 but when I enter again the option is MTP+ADB. And when I type *#7284# and select the "modem" nothing hapend |
01-24-2015, 00:21 | #10 (permalink) | |
Member: 370221 Status: Offline Sonork: 1592059 Thanks Meter: 97 | Me again, with a new one Quote:
01-24-2015, 08:40 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Disconnect all other devices from PC, reboot the PC and try to connect the phone again. To connect GT-I8550L, perform the following steps: 1. Disconnect Micro USB cable from the phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "USB" value. 14. Restart the phone. 15. Press "Read Info" in Octopus Samsung software. Write here, whether all the steps has been performed successfully or were problems with some of them. Also say, what device appears in PC Device Manager, when You perform steps 1-15 and connect the device to PC. |
01-24-2015, 16:57 | #12 (permalink) | |
Hello, I follow all the steps, but when I restart the phone it come back to the original state, and if I conect the device to pc and try to change the options nothing hapend the changes can´t be make.: *#0808# (mtp+adb) *#7284# (nothing select) *#9090# (usb) >>>> works | |
01-24-2015, 17:23 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to re-flash the phone with firmware from the Support Area, then repeat the steps required for connection and try to read phone's info on both "Main" and "Android/EFS manager" tabs of the Software. |
