Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 06-20-2012, 14:19   #1 (permalink)
Member: 10011
How to unlock i9070P? [Solved]
Hi
I have downloaded the patched file from support for the i9070, flashed the phone with it. After a successful flash the phone has no imei number, and won't respond to any sim card. Thinking that this is normal behavior I carried on with the unlock process, pressed the unlock button, octopus software signaled a successful unlock. In order to get my phone back to a functional state I flashed a not patched firmware into it. i got back my imei number, and when I insert a sim card from another network, the phone asks for the network unlock code. The code 00000000 is not working. I don't have the sim card that this phone is locked to, so I cannot test with it.
Here's the log of operation:
Welcome to Octopus Box Samsung software version 1.4.6
To connect GT-I9070P phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "UART" radio button to "Modem" value.
8. Close window.
9. Press "Read Info" in Octopus Samsung software.
Selected firmware file: GT-I9070_for_Unlock_and_Repair_IMEI.oct
Please put your phone in download mode and connect to PC.
To put GT-I9070P phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - "  + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing Kernel section...
Kernel section has been written successfully.
Writing Modem section...
Modem section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing CACHEFS section...
CACHEFS section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Anycall
Selected port: COM1
Selected model: GT-I9070P
Searching for phone. Please wait...
Detect Model Name: GT-I9070
S/W version: I9070VJLD1
Phone IMEI: NONE
OK
X
Selected port: COM25
Phone IMEI: NONE
OK
X
Unlocking phone...
Deactivating MSL...
MSL deactivate successfully
Unlocking phone. It can take some time. Please wait...
Please insert card into phone, if phone is locked, then type 00000000
Phone is successfully unlocked
Can someone help me troubleshoot this problem?
Thanks in advance
d3m0n
Old 06-20-2012, 14:41   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Please try to do the next:
1. Write again "GT-I9070_for_Unlock_and_Repair_IMEI".
2. Make Unlock again, upload somewhere last "*.logx" file from "c:\Program Files\GsmServer\OctopusSamsung\LOG\" and post here link.
3. Insert SIM card into phone, if phone is locked, then type 00000000.
4. Write here if code accepted.
Check if the phone will be unlocked.
Old 06-21-2012, 08:42   #3 (permalink)
Member: 10011
When I flash the phone with the GT-I9070_for_Unlock_and_Repair_IMEI.oct file, it does not work properly. It powers on, but it acts as it has no modem written. It does not ask for an unlock code. The NFC option is not present under "Wireless and network", and when i try to go to the "Wireless and network - Mobile Networks" option, the phone asks to put a sim card in it, but the sim is inserted into the phone. I can fix this by flashing another flash file into the phone, but then, when i insert a sim card, it asks for a code, but it wont accept 00000000.
Here are the log files you requested, and I also attached a screenshot of the phone when it was flashed with the repair flash file (notice the little circle on the left side of the battery indicator, and on the second screenshot it shows that the phone has no imei number)
http://dl.dropbox.com/u/31318714/i9070p_Log.zip
br
d3m0n
Old 06-21-2012, 11:36   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
We have uploaded new special firmware for GT-I9070P ("GT-I9070P_for_Unlock_and_Repair_IMEI"). This firmware will be available on the server in 30 minutes. Please download it, write it to your phone and make Unlock again. Then post here the result.
Old 06-21-2012, 13:59   #5 (permalink)
Member: 10011
Unlock done!!! :-)
After flashing the GT-I9070P_for_Unlock_and_Repair_IMEI.oct file, and pressing unlock, the phone would not register to a network. Searching manually for available networks, didn't find any. After flashing the phone with an original flash file, with odin 1.85, it registered to a network without problems. It did not ask for a network code, so I didn't had to enter 00000000.
So steps that worked for me:
1 flash GT-I9070P_for_Unlock_and_Repair_IMEI.oct via octopus
2 after phone wakes up, type on the phone *#7284#, and select UART Modem
3 connect phone to microuart cable (c3300 cable worked for me)
4 press unlock on octopus software
5 flash phone with an original flash file
6 unlock done
Thanks to Octopus team
br
d3m0n
The Following User Says Thank You to demon For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.58279 seconds with 11 queries
