12-16-2014, 05:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2014 Location: gsm forum
Member: 2263030 Status: Offline Sonork: 100.1659104 Thanks Meter: 23 | how to unlock i9301i 2. Re-start the phone. 3. Root the phone by using TowelRoot. 4. Write the second service's IMEI from the Software list. 5. Make Repair 3G/4G. 6. Restart the phone. 7. Write the first NVM backup (that You or Software was performed fore You have performed before first "Unlock" or "Repair IMEI" operation) or try to write this NVM backup https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA. 8. Write here full Software log with all of these actions. i think every one will writesecond imei....can one imei works on many handsets.... log Platform: Samsung Android Selected port: COM3 Selected model: GT-I9301I Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9301I Firmware compiled date: Wed Sep 3 13:35:49 KST 2014 PDA version: I9301IXXUANI1 CSC version: I9301IITVANJ1 SW version: I9301IXXUANI2 Phone IMEI: 355835060==== Phone SN: RV1F81FZ0YY Android version: 4.4.2 (KOT49H) ------------------------------------------ i cant read efs and security help me...... Platform: Samsung Android Selected port: COM3 Selected model: GT-I9301I ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. |
12-16-2014, 13:38 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do exactly the next: 1. Write firmware "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOM E" from the Support Area. 2. Re-start the phone. 3. Root the phone by using TowelRoot. 4. Make Unlock again. 5. Make Repair 3G/4G. 6. Restart the phone. 7. Write this NVM backup https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA 8. Write here full Software log with all of these actions. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
12-16-2014, 17:47 | #4 (permalink) | |
Major Poster Join Date: May 2013 Location: Rise up....
Member: 1930199 Status: Offline Sonork: 100.1641048 Thanks Meter: 3 | Quote:
But sir I can't backup nvm | |
12-16-2014, 17:57 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Perform steps 1-3 from previous post. Then do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Connect the phone directly to PC. 15. Press "Read Info" in software. After these steps You we will be able to create backups and continue with steps 4-8. Note: You should press "OK/Grant/Allow" button on every pop-up dialogue, which may appear on phone's screen during these operations. |
