Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-03-2014, 17:50   #1 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
how to unlock i9305 4.3? [Solved]
possible to unlock i9305 4.3
thanx
Old 03-03-2014, 17:56   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
To unlock your device, do the next:
1. Install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual).
2. Root the phone manually.
3. Perform "Unlock" operation.
Old 03-04-2014, 09:21   #3 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
Welcome to Octoplus/Octopus Box Samsung software version 1.5.0
To connect GT-I9305 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "MODEM" value.
8. Go to "Qualcomm USB Settings".
9. Select "RNDIS+DM+MODEM".
10. Enter "*#9090#" number.
11. Select DM/DUM over HS-USB.
12. Close window.
13. Go to dial window.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM13
Selected model: GT-I9305
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM13
Mode: Emergency
Mode: Emergency
Codes for GT-I9305 phone in emergency mode can’t be read
Mode: Emergency
Selected port: COM5
No diagnostic ports found!
Connecting to phone on COM5
Phone connection failed
Selected port: COM5
Selected port: COM5
Selected port: COM5
Mode: Normal
Phone model: GT-I9305
Firmware compiled date: Dec 21 2012
Firmware compiled time: 03:00:00
Firmware released date: Nov 2 2013
Firmware released time: 14:12:25
Phone IMEI: 356026-05-113816-7
SW version: M9615ACEHWMAZD179599
Selected port: COM5
Mode: Normal
Reading phone unlock codes. It can take some time, please wait...
Reading security failed
Read codes failed
Selected port: COM5
Mode: Emergency
Reading codes canceled
Selected port: COM5
Mode: Normal
Selected port: COM5
Mode: Normal
Read codes failed
Selected port: COM5
Mode: Normal
Selected port: COM5
Mode: Normal
Unlocking phone...
Phone unlocking failed
Old 03-04-2014, 13:01   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
There is new (currently not supported) security type in your device. Please, read backups of EFS and Security from your device by using test Software version, which we have prepared for You and send us.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 03-04-2014, 14:56   #5 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
Downgrader de 4.3 à 4.1.2
resultat: firmware upgrade encounterd an issue please select recouvery mode
Old 03-04-2014, 15:21   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Re-flash the phone with the firmware with Android 4.3 from the Support Area.
Old 03-05-2014, 09:02   #7 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
problem solved
flash+repair imei ok
how to unlock
12. Close window.
Selected firmware file: I9305XXUEMKC_I9305TPHEMK1
_TPH_Portugal_Android_4.3.oct
Please switch your phone to the download mode and connect it to a
PC.
To put GT-I9305 phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing BOOT section...
BOOT section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Writing RADIO section...
RADIO section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing TZSW section...
TZSW section has been written successfully.
Writing BOOTLOADER section...
BOOTLOADER section has been written successfully.
Firmware writing successfully completed.
Selected port: COM1
Mode: Normal
Incorrect IMEI
Mode: Normal
Old IMEI: 004400-15-202000-0
New IMEI: 351247-88-546555-1
IMEI successfully repaired.
To finish the operation, please restart the phone via phone's menu
(don't disconnect the battery!)
The Following User Says Thank You to rai14 For This Useful Post:
Page generated in 0.17716 seconds with 8 queries
