12-09-2016, 19:00 | #1 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1709865 Status: Offline Thanks Meter: 20 | How to unlock samsung j120az Amp2 [Solved] here log thanks Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\09-12-2016_10-31-58.log" created (09/12/2016 10:32:01 a.m.). INFO : 09/12/2016 10:32:11 a.m. > Set up system language Spanish (file: Spanish - копия.ini) INFO : 09/12/2016 10:32:11 a.m. > Welcome to Octoplus/Octopus Box Samsung software version 2.4.5 INFO : 09/12/2016 10:32:19 a.m. > ----------------------------------------------------------------------------------- INFO : 09/12/2016 10:32:19 a.m. > To connect SCL24 phone you have to perform the following steps: INFO : 09/12/2016 10:32:19 a.m. > 1. Disconnect USB cable from phone. INFO : 09/12/2016 10:32:19 a.m. > 2. Go to Menu->Settings->More->About Device. INFO : 09/12/2016 10:32:19 a.m. > 3.Tap on "Build number" 7 times to enable developer options. INFO : 09/12/2016 10:32:19 a.m. > 4. Go to Menu->Settings->More->Developer options. INFO : 09/12/2016 10:32:19 a.m. > 5. Turn on "USB Debugging" option. INFO : 09/12/2016 10:32:19 a.m. > 6. Go to dial window. INFO : 09/12/2016 10:32:19 a.m. > 7. Enter "*#0808#" number. INFO : 09/12/2016 10:32:19 a.m. > 8. Select "DM+Modem+ADB". INFO : 09/12/2016 10:32:19 a.m. > 9. Press Home button. INFO : 09/12/2016 10:32:19 a.m. > 10. Restart phone. INFO : 09/12/2016 10:32:19 a.m. > 11. Press "Read Info" in software. INFO : 09/12/2016 10:33:24 a.m. > ----------------------------------------------------------------------------------- INFO : 09/12/2016 10:33:24 a.m. > To connect SM-J120AZ phone you have to perform the following steps: INFO : 09/12/2016 10:33:24 a.m. > 1. Disconnect USB cable from phone. INFO : 09/12/2016 10:33:24 a.m. > 2. Go to Menu->Settings->More->About Device. INFO : 09/12/2016 10:33:24 a.m. > 3.Tap on "Build number" 7 times to enable developer options. INFO : 09/12/2016 10:33:24 a.m. > 4. Go to Menu->Settings->More->Developer options. INFO : 09/12/2016 10:33:24 a.m. > 5. Turn on "USB Debugging" option. INFO : 09/12/2016 10:33:54 a.m. > ----------------------------------------------------------------------------------- INFO : 09/12/2016 10:33:54 a.m. > Platform: Samsung Android INFO : 09/12/2016 10:33:54 a.m. > Selected port: COM7 INFO : 09/12/2016 10:33:54 a.m. > Selected model: SM-J120AZ INFO : 09/12/2016 10:33:54 a.m. > Searching for a phone. Please wait... WARN : 09/12/2016 10:33:55 a.m. > Please, press "OK" button on the phone to allow USB debugging.. INFO : 09/12/2016 10:33:58 a.m. > Phone found. INFO : 09/12/2016 10:33:59 a.m. > Detected phone model: SM-J120AZ INFO : 09/12/2016 10:33:59 a.m. > Firmware compiled date: Fri Oct 14 14:35:10 KST 2016 INFO : 09/12/2016 10:33:59 a.m. > PDA version: J120AZTUU2APJ2 INFO : 09/12/2016 10:33:59 a.m. > CSC version: J120AZAIO2APJ2 INFO : 09/12/2016 10:33:59 a.m. > SW version: J120AZTUU2APJ2 INFO : 09/12/2016 10:34:00 a.m. > Phone SN: R58HB40RGBA INFO : 09/12/2016 10:34:00 a.m. > Android version: 6.0.1 (MMB29K) INFO : 09/12/2016 10:34:00 a.m. > Sales code: AIO INFO : 09/12/2016 10:34:00 a.m. > Country: USA INFO : 09/12/2016 10:34:00 a.m. > HW platform: exynos3 INFO : 09/12/2016 10:34:00 a.m. > HW Chip: exynos3475 INFO : 09/12/2016 10:34:00 a.m. > HW Modem: SHANNON308 INFO : 09/12/2016 10:34:00 a.m. > Codename: j1xltetu INFO : 09/12/2016 10:34:00 a.m. > Performed by 2.4.5 Software version. INFO : 09/12/2016 10:34:02 a.m. > ----------------------------------------------------------------------------------- INFO : 09/12/2016 10:34:03 a.m. > Platform: Samsung Android INFO : 09/12/2016 10:34:03 a.m. > Selected port: COM7 INFO : 09/12/2016 10:34:03 a.m. > Selected model: SM-J120AZ INFO : 09/12/2016 10:34:03 a.m. > Searching for a phone. Please wait... INFO : 09/12/2016 10:34:08 a.m. > Found phone on COM8 INFO : 09/12/2016 10:34:08 a.m. > Reading info... INFO : 09/12/2016 10:34:12 a.m. > Detected phone model: INFO : 09/12/2016 10:34:12 a.m. > HW Version: SM2J120AZKZAIO INFO : 09/12/2016 10:34:12 a.m. > PDA version: J120AZTUU2APJ2 INFO : 09/12/2016 10:34:12 a.m. > CSC version: J120AZAIO2APJ2 INFO : 09/12/2016 10:34:12 a.m. > CP version: J120AZTUU2APJ2 INFO : 09/12/2016 10:34:12 a.m. > Phone SN: R58HB40RGBA INFO : 09/12/2016 10:34:12 a.m. > Phone IMEI: 356419-07-555837-1 INFO : 09/12/2016 10:34:12 a.m. > Reading codes... ERROR : 09/12/2016 10:34:18 a.m. > error code 1 ERROR : 09/12/2016 10:34:18 a.m. > Read codes failed INFO : 09/12/2016 10:34:18 a.m. > Performed by 2.4.5 Software version. INFO : 09/12/2016 10:37:36 a.m. > ----------------------------------------------------------------------------------- INFO : 09/12/2016 10:37:37 a.m. > Platform: Samsung Android INFO : 09/12/2016 10:37:37 a.m. > Selected port: COM8 INFO : 09/12/2016 10:37:37 a.m. > Selected model: SM-J120AZ INFO : 09/12/2016 10:37:37 a.m. > Searching for a phone. Please wait... INFO : 09/12/2016 10:37:39 a.m. > Found phone on COM8 INFO : 09/12/2016 10:37:39 a.m. > Reading info... INFO : 09/12/2016 10:37:43 a.m. > Detected phone model: INFO : 09/12/2016 10:37:43 a.m. > HW Version: SM2J120AZKZAIO INFO : 09/12/2016 10:37:43 a.m. > PDA version: J120AZTUU2APJ2 INFO : 09/12/2016 10:37:43 a.m. > CSC version: J120AZAIO2APJ2 INFO : 09/12/2016 10:37:43 a.m. > CP version: J120AZTUU2APJ2 INFO : 09/12/2016 10:37:43 a.m. > Phone SN: R58HB40RGBA INFO : 09/12/2016 10:37:43 a.m. > Phone IMEI: 356419-07-555837-1 INFO : 09/12/2016 10:37:43 a.m. > Unlocking phone... ERROR : 09/12/2016 10:37:47 a.m. > error code 0 ERROR : 09/12/2016 10:37:47 a.m. > Phone unlocking failed INFO : 09/12/2016 10:37:47 a.m. > Performed by 2.4.5 Software version. Last edited by Octopus box; 12-11-2016 at 07:18. |
12-10-2016, 09:13 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Your phone has one of the latest firmwares with new type of Security. To process such phone You can try to write older (by release date) firmware. |
12-11-2016, 05:34 | #3 (permalink) |
Member: 1709865 Status: Offline Thanks Meter: 20 | thanks team,but already unlocked this phone, just choose j320az and read codes,and done! Last edited by Octopus box; 12-11-2016 at 07:19. |
The Following User Says Thank You to patosky2012 For This Useful Post: |
