01-19-2015, 07:20 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2100924 Status: Offline Thanks Meter: 19 | How to unlock samsung S5 docomo SC-04F? [Solved] But I'm having problems with one another sc-04F, the dark can not write imei to perform write crett .... octupus notice delete EFS done but imei still be there ..... I can not delete imei to write crett. please help me. Last edited by Octopus box; 01-19-2015 at 10:03. |
01-19-2015, 09:58 | #3 (permalink) |
Member: 2100924 Status: Offline Thanks Meter: 19 | Thank octupus, I would like to be completed after the first fix file errors, I fix it with odin flash file then I deleted successfully imeihanh and write crett OK, I've successfully unlocked Sc-04F with octupus ... .. thank you for guidance File bug fix: File bug fix was created by a master Admin : gsm24h.vn ( thank you ) DONE ::: |
01-19-2015, 10:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, thanks for your report. What model You have selected in the Software list and what IMEI Certificate file (for what model) You have used? Can You also send us to PM these Cache amd Recovery files? |
01-20-2015, 03:51 | #5 (permalink) | |
Member: 2100924 Status: Offline Thanks Meter: 19 | Quote:
The secret lies in the fix file errors, please look for the cause teams to overcome problems without need to file another bug fix. | |
01-20-2015, 04:09 | #6 (permalink) |
Member: 2100924 Status: Offline Thanks Meter: 19 | I sent the file to your inbox. You can use it to study, but if you want to share, then please feel free to contact the owner of it. octuplus team hopes to find a solution to fix processing error EFS is not removed in one of the special cases. for assistance please contact my teacher yahoo: dienthoaimiennam Last edited by zintung2911; 01-20-2015 at 04:16. |
01-20-2015, 08:12 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | This is not a bug, if You can't wipe Security, You should write cache and recovery files after rooting the phone and then it will be possible to make Wipe Security. The same things are also for Note 4 devices, look here: http://forum.gsmhosting.com/vbb/10787345-post81.html. These files are simple cache and recovery files from the original firmware, nothing special. Anyway, thanks for files. |
01-20-2015, 11:10 | #8 (permalink) |
Member: 2100924 Status: Offline Thanks Meter: 19 | You should write cache and recovery files after rooting the phone and then it will be possible to make Wipe Security !!! I do not know at this stage, you can explain to me. to fix this when I encounter cases can not delete EFS ..... easy |
01-20-2015, 11:19 | #9 (permalink) | |
https://www.youtube.com/watch?v=oA_TLjNTwI4 I do not know at this stage, you can explain to me. khi to fix this encounter I can not delete EFS Cases easy ..... thank you much I understand problems viewing this clip | |
